September 27, 2017, 11:44 |
Calculation of Drag Coefficients
Rep Power: 8 |
Hello everyone,
currently I am struggling with the calculation of drag for an Ahmed Body. My first Question is how dows OpenFOAM calculate the drag? I assume it integrates the difference in pressure and the shering stress on the surface and adds them both, is that correct? I am using the library libforces.so: Code:
forceCn { type forceCoeffs; libs ( "libforces.so" ); writeControl timeStep; writeInterval 1; patches ( "Nose"); rho rhoInf; pRef 0; log true; rhoInf 1.2; liftDir (0 0 1); dragDir (1 0 0); CofR (0.72 0 0); pitchAxis (0 1 0); magUInf 40; lRef 1.42; Aref 0.112; } My calculations deliver 0.3. Therefore my absolute drag coefficient of the Ahmed Body ist about two times higher than in the paper. The drag coefficients at the back and rear slop are almost the same as in the paper, it is just the drag coefficient at the nose of the body. And why is the drag coefficient at the rear slop and the back positive anyway? Isnt it supposed to be negative, because the pressure difference is negativ? Thanks for any advice, I hope u can help! Greetings, Friendly |
Lift and drag coefficients of the NACA 0018 | Volodymyr | CONVERGE | 4 | September 22, 2017 17:52 |
drag and lift coefficients in axisymmetric and 3D simulations! | CFD-Lover | OpenFOAM Running, Solving & CFD | 0 | July 1, 2017 16:33 |
Lift and Drag coefficients for flow past sphere | shashanktiwari619 | FLUENT | 0 | January 27, 2017 13:31 |
lift and drag coefficients around a ground vehicle | Pedro | CFX | 3 | September 5, 2012 18:31 |
