Compilation error for OpenFoam FSI solver with third party FEA code
Old   January 4, 2017, 12:35
Default Compilation error for OpenFoam FSI solver with third party FEA code
danny261083 is on a distinguished road
Hello All,
I had a concern regarding compilation of the OpenFoam FSI solver with a third party FEA code (e.g. CalculiX) as described by Dr. Robert Campbell in the 6th OpenFoam workshop (http://www.personal.psu.edu/dab143/O...ell_slides.pdf). I downloaded and copied the related code to the run folder and attempted to compile the solver using the wmake command. However, I received compilation errors (see attached text file). I am not sure whether the errors are associated with the version of openfoam that I am using (foam-extend 3.1). I was also wondering whether I could get some tips on replacing the fictitious structural class included in the code with a FE solver input file for the FSI problem.
Thanks
File Type: txt FSI 6th OF Workshop Compilation Error.txt (4.3 KB, 7 views)
danny261083 is offline   Reply With Quote
Old   October 6, 2017, 09:50
Smile Any improvements?
Thaw Tar's Avatar
Thaw Tar
Thaw Tar is on a distinguished road
I also looked at the code and the test case of training session by Dr. Campbell although I have not compiled it on my computer. And now I am also wondering how to couple OpenFOAM with third party structural solver via his skeleton class...
Another thing I noticed is in his test case, he used fixedValue boundary condition for the plate. In my opinion, we are supposed to use movingWallVelocity BC. Actually, I tried ElmerFoamFSI code. In this code, I could run the tutorial HronTurek FSI3 case well if I use fixedValue BC for the plate. However, if I use movingWallVelocity BC, it simply diverges and crashed after, say, 4 time steps.
Could you please share any new knowledge about this?
Thaw Tar
Thaw Tar is offline   Reply With Quote
fea fsi not supporting parallel whereas other cases suports in version4 varghese9 SU2 1 July 15, 2015 12:59
thobois class engineTopoChangerMesh error Peter_600 OpenFOAM 4 August 2, 2014 09:52
which FSI solver is the best ? mechy OpenFOAM 0 January 19, 2012 17:28
Question on coupled FSI in CCM+ with a third party software daveatstyacht Siemens 1 January 20, 2011 21:28
Design Integration with CFD? John C. Chien Main CFD Forum 19 May 17, 2001 15:56
