actual flow rate not match the designed flow rate in ventilation modeling
Old   November 18, 2018, 07:10
Default actual flow rate not match the designed flow rate in ventilation modeling
Pu Gong
minecraftgp is on a distinguished road
Hi foamers
I am doing a displacement ventilation modeling of a single office with a seated occupants which generating heat thermal plume using buoyantBoussinesqPimpleFoam. The inlet and outlet size are both 0.2×0.2=0.04m2, the inlet velocity is 0.25m/s, hence as my expect the volume flow rate of inlet (designed flow rate) and outlet should be 0.01m3/s, or 10L/s.
However, the actual volume flow rate result from flow rate monitor is 9L/s.
Anyone please help how can I make the actual flow rate the same as designed value?
minecraftgp is offline   Reply With Quote
Old   November 18, 2018, 08:11
Peter Baskovich
pete20r2 is on a distinguished road
Are you using fluxCorrected boundary conditions?
Please post more info, whole case is good in a zip or post the 0 folder and boundary files to start with.
pete20r2 is offline   Reply With Quote
Old   November 18, 2018, 12:37
Pu Gong
Hi Peter
Thanks for your reply. Please check my U, T and P-rgh files.
And what you mean by the fluxCorrected boundary condition? Is it a inlet outlet boundary condition that can be identified in the U file?
Cheers
FoamFile
    version     2.0;
    format      ascii;
    class       volVectorField;
    object      U;
dimensions      [0 1 -1 0 0 0 0];
internalField   uniform (0 0 0);
boundaryField
    inlet
        type            fixedValue;
        value           uniform (0.25 0 0);
    outlet
        type            inletOutlet;
        inletValue      uniform (0 0 0);
	value           uniform (0 0 0);
	top
        type            noSlip;
    bottom
        type            noSlip;
    wall
        type            noSlip;
    desk
        type            noSlip;
    human
        type            noSlip;
FoamFile
    version     2.0;
    format      ascii;
    class       volScalarField;
    object      T;
dimensions      [0 0 0 1 0 0 0];
internalField   uniform 298.15;
boundaryField
    inlet
        type            fixedValue;
        value           uniform 298.15;
    outlet
        type            fixedValue;
    top
        type            fixedValue;
    bottom
        type            fixedValue;
	wall
        type            fixedValue;
    desk
        type            fixedValue;
    human
        type            fixedValue;
FoamFile
    version     2.0;
    format      ascii;
    object      p_rgh;
dimensions      [0 2 -2 0 0 0 0];
internalField   uniform 0;
boundaryField
    inlet
        type            fixedValue;
        value           uniform 0;
    outlet
        type            fixedValue;
        value           uniform 0;
    top
        type            fixedFluxPressure;
        rho             rhok;
        value           uniform 0;
    bottom
        rho             rhok;
        value           uniform 0;
    wall
        rho             rhok;
        value           uniform 0;
    desk
        rho             rhok;
        value           uniform 0;
    human
        rho             rhok;
        value           uniform 0;
Flow rate restriction simulation set-up siw CFX 4 February 16, 2016 12:15
CFD Modeling of Two-phase Flow in Small Dia.Tubes Eric Poindexter Main CFD Forum 2 September 22, 2000 09:21
fluid flow fundas ram Main CFD Forum 5 June 17, 2000 21:31
Hydrostatic pressure in 2-phase flow modeling (CFX4.2) HB &DS CFX 0 January 9, 2000 13:19
Hydrostatic pressure in 2-phase flow modeling (long) DS & HB Main CFD Forum 0 January 8, 2000 15:00
