Initial Perturbation of Interface in Rayleigh-Taylor Instability
I am using buoyantPimpleFoam to simulate Rayleigh-Taylor instability of air with a hot gas on the lower portion of the domain (T = 900 K) and cold air on top (T = 300 K). Pressure being 101.325 kPa and g = (0,-9.81,0) m/s^2. I originally tried to perturb the interface by a simple cosine function f(x) = 0.05/2*(1+cos(2*pi*x)), but the mesh resolution created a "stair step" situation where the small steps acted as artificial perturbation surfaces.
https://imgur.com/GCtQuVbhttps://imgur.com/TP0rx7R https://imgur.com/mXQDZGIhttps://imgur.com/mXQDZGI This a short video of how the "stair stepping" forces the flow to behave: https://imgur.com/TP0rx7R I tried running this at a finer resolution, but the behavior is still the same and becomes economically less practical as you refine this more and more. My next attempt was to apply a perturbation to the y-velocity instead. The idea being that the baroclinic vorticity generation (cause of the RT growth) occurs across the density gradient, thus any "stair stepping" would cause instability growth. Thus as long as the density interface is flat, then the above problems would not be present. The perturbation velocity would then force small fluid motion leading to interface movement without the effects of the mesh present. I did this via the following function: Vy = 0.01/4*(1+cos(2*pi*x))*(1+cos(100*pi*y)) But when I ran this for over a second, the interface had not moved even a little bit. I'm not quite sure why the above didn't work. Is there a different way to perturb the interface in OpenFoam that would avoid the mesh issue? And if my solution is the correct method, then why was I not able to get fluid motion? |
Can you use a VOF number instead of pure species to smooth the interface?
I have a similar problem when I simulated mass transfer of the interface in Fluent.
Jagged lines will make the evolution of the sinusoid interface become out of expectation. I wonder whether you have solved the problem and please do me a favor to give me some suggestion. |
Dear AMK53,
Greetings. I am wondering how did you add the perturbation. Thanks |
As Peter mentioned you can use VOF for RT instability. You can use two different fluid with given gas densities. Regards, -Yogesh |
Hey @Bodo1993! Its possible to use either a codestream in the 0/alpha.water file or use funkySetFields with swak4Foam. To implement the code stream, add this to your 0/alpha.water:
``` internalField #codeStream { codeInclude #{ #include "fvCFD.H" #}; codeOptions #{ -I$(LIB_SRC)/finiteVolume/lnInclude \ -I$(LIB_SRC)/meshTools/lnInclude #}; codeLibs #{ -lmeshTools \ -lfiniteVolume #}; code #{ const IOdictionary& d = static_cast<const IOdictionary&>(dict); const fvMesh& mesh = refCast<const fvMesh>(d.db()); scalarField alpha(mesh.nCells(), 0.); forAll(alpha, i) { const scalar x = mesh.C()[i][0]; const scalar y = mesh.C()[i][1]; if (y >= 2.1 + 0.1*Foam::pow(cos(constant::mathematical::pi*x)*co s(constant::mathematical::pi*x), 2)) { alpha[i] = 1.; } } Foam::writeEntry(os,alpha); #}; }; ``` This is for openfoam 7. |
Thanks a lot for your time. Kindly, it will be very helpful to know the alternative approach as well (the funkySetFields one). Much appreciated. |
