September 12, 2017, 12:49 |
OverSimpleFlow Interpolation problem
Ajeje Brazov
Rep Power: 9 |
I am trying to use OverSimpleFoam for the simulation of a wind turbine. In order to understand how it works I created a simpler case as you can see from the images. In the first image you can see the cylinder that represent the blade. In the second there is the structured mesh extruded from the blade in which the overset patch is defined. The problem is that I don't have any interpolated cells and I don't understand why. I have also very high yPSi residuals and I don't know what yPsi is. I attached the case with every file of the simulation. Could you please explain how can I run the case? Thank you! |
October 25, 2017, 05:25 |
#2 | |
Felix Weiler
Rep Power: 9 |
Hi Ajeje,
have you had any progress regarding this topic? Quote:
oversimplefoam ypsi |
Display Modes | |
area does not match neighbour by ... % -- possible face ordering problem | St.Pacholak | OpenFOAM | 10 | February 7, 2024 21:50 |
Mapping (interpolation) between two meshes | Ebrahim | OpenFOAM Programming & Development | 2 | June 15, 2020 13:31 |
Boco interpolation problem | sufjanst | FLUENT | 4 | August 18, 2017 08:26 |
Heat Transfert, mixing problem | Wazdq | CFX | 8 | November 7, 2016 05:44 |
Interpolation problem! | Severin | FLUENT | 1 | July 28, 2006 06:10 |
