Problem running atmBoundaryLayerInlet
Old   November 18, 2017, 16:36
Default Problem running atmBoundaryLayerInlet
Tommaso Pascon
Pervispasco is on a distinguished road
Hi everyone,
I'm having troubles running a simple 3D RANS flow over a cube.
It works perfectly fine with uniform inlet velocity, but as soon as I use the atmBoundarylayerinlet for U and Epsilon, everything stop working.
I simply copied the two files of the turbine tutorial in simpleFoam directory.
These are mine U and Epsilon files:
|  \\    /   O peration     | Version:  2.3.x                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
/*  Windows port by CFD support (www.cfdsupport.com) [based on Symscape]     *\
FoamFile
    version     2.0;
    format      ascii;
    class       volVectorField;
    location    "0.01";
    object      U;
dimensions      [0 1 -1 0 0 0 0];
internalField   uniform (0 0 0);
boundaryField
    buildings
        type            fixedValue;
        value           uniform (0 0 0);
    ground
        type            fixedValue;
    frontAndBack
        type            symmetry;
    inlet
            type            atmBoundaryLayerInletVelocity;
                Uref                 10.0;
                Zref                 20;
                zDir                 (0 0 1);
                flowDir              (1 0 0);
                z0                   uniform 0.1;
                zGround              uniform 935.0;
                value                $internalField;
    outlet
        type            zeroGradient;
FoamFile
    version     2.0;
    format      ascii;
    class       volScalarField;
    location    "0.01";
    object      epsilon;
dimensions      [0 2 -3 0 0 0 0];
internalField   uniform 9.98e-06;
boundaryField
    buildings
        type            epsilonWallFunction;
        value           uniform 9.98e-06;
    ground
    frontAndBack
        type            symmetry;
    inlet
     type            atmBoundaryLayerInletEpsilon;
        Uref                 10.0;
        Zref                 20;
        zDir                 (0 0 1);
        flowDir              (1 0 0);
        z0                   uniform 0.1;
    outlet
        type            zeroGradient;
And this is what I get from OpenFoam when I try to run the case:
smoothSolver: Solving for Ux, Initial residual = nan, Final residual = nan, No Iterations 1000
smoothSolver: Solving for Uy, Initial residual = nan, Final residual = nan, No Iterations 1000
smoothSolver: Solving for Uz, Initial residual = nan, Final residual = nan, No Iterations 1000
GAMG: Solving for p, Initial residual = nan, Final residual = nan, No Iterations 1000
time step continuity errors : sum local = nan, global = nan, cumulative = nan
smoothSolver: Solving for epsilon, Initial residual = nan, Final residual = nan, No Iterations 1000
smoothSolver: Solving for k, Initial residual = nan, Final residual = nan, No Iterations 1000
ExecutionTime = 386.812 s ClockTime = 386 s
forces forces output:
sum of forces:
pressure : (nan nan nan)
viscous : (nan nan nan)
porous : (0 0 0)
sum of moments:
porous : (0 0 0)
forceCoeffs forceCoeffs output:
Cm = nan
Cd = nan
Cl = nan
Cl(f) = nan
Cl(r) = nan
fieldAverage fieldAverage1 output:
Calculating averages
Time = 5
What could be the issue?
Thanks
Pervispasco is offline   Reply With Quote
Problem About Running Fluent In Linux mitra FLUENT 18 June 20, 2019 02:11
Problem running angledDuct tutorial of porousSimpleFoam Anindya1 OpenFOAM Running, Solving & CFD 0 January 24, 2016 10:02
Non- stop running for a time-dependent heat source problem Asghari_M OpenFOAM Programming & Development 1 May 11, 2015 05:13
problem with running in parallel dhruv OpenFOAM 3 November 25, 2011 05:06
Kubuntu uses dash breaks All scripts in tutorials platopus OpenFOAM Bugs 8 April 15, 2008 07:52
