Different results when running OpenFOAM on different sys |
TWB
Rep Power: 20 ![]() |
I tried to run a turbulent case with openfoam. On one cluster, it diverges at the 3rd time step. On another, it completed w/o any problem. I have shown the output below. Is there any reason why? They're using the same config file with the same no. of processors. Please advice. cluster1: Mean and max Courant Numbers = 0.0998 1.067 Flow time scale min/max = 4.687e-07, 2.869e-06 Time = 3e-06 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 diagonal: Solving for rhoUx, Initial residual = 0, Final residual = 0, No Iterations 0 diagonal: Solving for rhoUy, Initial residual = 0, Final residual = 0, No Iterations 0 diagonal: Solving for rhoUz, Initial residual = 0, Final residual = 0, No Iterations 0 smoothSolver: Solving for Ux, Initial residual = 0.001212, Final residual = 7.712e-17, No Iterations 2 smoothSolver: Solving for Uy, Initial residual = 0.003422, Final residual = 2.676e-16, No Iterations 2 smoothSolver: Solving for Uz, Initial residual = 0.003535, Final residual = 2.487e-16, No Iterations 2 diagonal: Solving for rhoE, Initial residual = 0, Final residual = 0, No Iterations 0 smoothSolver: Solving for e, Initial residual = 2.144e-05, Final residual = 6.111e-16, No Iterations 2 smoothSolver: Solving for omega, Initial residual = 0.0001931, Final residual = 2.311e-11, No Iterations 2 bounding omega, min: 0 max: 3.156e+05 average: 1449 smoothSolver: Solving for k, Initial residual = 0.1251, Final residual = 4.293e-09, No Iterations 2 bounding k, min: 0 max: 0.9901 average: 0.9261 ExecutionTime = 1.21 s ClockTime = 2 s Mean and max Courant Numbers = 0.103 1.086 Flow time scale min/max = 4.606e-07, 2.755e-06 Time = 4e-06 cluster2: Mean and max Courant Numbers = 0.0998 1.067 Flow time scale min/max = 4.687e-07, 2.869e-06 Time = 3e-06 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 diagonal: Solving for rhoUx, Initial residual = 0, Final residual = 0, No Iterations 0 diagonal: Solving for rhoUy, Initial residual = 0, Final residual = 0, No Iterations 0 diagonal: Solving for rhoUz, Initial residual = 0, Final residual = 0, No Iterations 0 smoothSolver: Solving for Ux, Initial residual = 0.001212, Final residual = 8.159e-17, No Iterations 2 smoothSolver: Solving for Uy, Initial residual = 0.003422, Final residual = 2.783e-16, No Iterations 2 smoothSolver: Solving for Uz, Initial residual = 0.003535, Final residual = 2.524e-16, No Iterations 2 diagonal: Solving for rhoE, Initial residual = 0, Final residual = 0, No Iterations 0 smoothSolver: Solving for e, Initial residual = 2.144e-05, Final residual = 6.481e-16, No Iterations 2 [21] #0[23] #0 Foam::error: ![]() ![]() ![]() ![]() ![]() ![]() [21] #1 Foam::sigFpe::sigHandler(int) at ??:? [23] #1 Foam::sigFpe::sigHandler(int) at ??:? [18] #1 Foam::sigFpe::sigHandler(int) at ??:? [18] #2 ? at ??:? [11] #1 Foam::sigFpe::sigHandler(int) at ??:? [10] #1 Foam::sigFpe::sigHandler(int) at ??:? [23] #2 ? at ??:? [21] #2 ? in "/lib/x86_64-linux-gnu/libc.so.6" [18] #3 Foam::divide(Foam::Field<double>&, Foam::UList<double> const&, Foam::UList<double> const&) in "/lib/x86_64-linux-gnu/libc.so.6" [21] #3 Foam::divide(Foam::Field<double>&, Foam::UList<double> const&, Foam::UList<double> const&) in "/lib/x86_64-linux-gnu/libc.so.6" [23] #3 Foam::divide(Foam::Field<double>&, Foam::UList<double> const&, Foam::UList<double> const&) at ??:? [11] #2 ? at ??:? [10] #2 ? at ??:? [18] #4 Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam: ![]() [11] #3 Foam::divide(Foam::Field<double>&, Foam::UList<double> const&, Foam::UList<double> const&) in "/lib/x86_64-linux-gnu/libc.so.6" [10] #3 Foam::divide(Foam::Field<double>&, Foam::UList<double> const&, Foam::UList<double> const&) at ??:? [23] #4 Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam: ![]() [21] #4 Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam: ![]() [18] #5 Foam::kOmegaSST<Foam::eddyViscosity<Foam::RASModel <Foam::EddyDiffusivity<Foam::ThermalDiffusivity<Fo am::CompressibleTurbulenceModel<Foam::fluidThermo> > > > >, Foam::EddyDiffusivity<Foam::ThermalDiffusivity<Foa m::CompressibleTurbulenceModel<Foam::fluidThermo> > > >::correct() at ??:? [21] #5 Foam::kOmegaSST<Foam::eddyViscosity<Foam::RASModel <Foam::EddyDiffusivity<Foam::ThermalDiffusivity<Fo am::CompressibleTurbulenceModel<Foam::fluidThermo> > > > >, Foam::EddyDiffusivity<Foam::ThermalDiffusivity<Foa m::CompressibleTurbulenceModel<Foam::fluidThermo> > > >::correct() at ??:? [23] #5 Foam::kOmegaSST<Foam::eddyViscosity<Foam::RASModel <Foam::EddyDiffusivity<Foam::ThermalDiffusivity<Fo am::CompressibleTurbulenceModel<Foam::fluidThermo> > > > >, Foam::EddyDiffusivity<Foam::ThermalDiffusivity<Foa m::CompressibleTurbulenceModel<Foam::fluidThermo> > > >::correct() at ??: |
TWB
I tested with 1 procs, and on another system. I got the same diverged solution after 3 time steps.
So how can I troubleshoot this problem? Where does it come from and what does the error message says? Hope someone can help. Thanks |
TWB
I finally found the reason for the difference. In one cluster, the sigfpe has been unset: unset FOAM_SIGFPE Hence, the error exception is not captured and stopped. Is this ok? Or correct So right now, after running for awhile, at t = 0.005, my residuals are: diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 diagonal: Solving for rhoUx, Initial residual = 0, Final residual = 0, No Iterations 0 diagonal: Solving for rhoUy, Initial residual = 0, Final residual = 0, No Iterations 0 diagonal: Solving for rhoUz, Initial residual = 0, Final residual = 0, No Iterations 0 smoothSolver: Solving for Ux, Initial residual = 2.268e-05, Final residual = 1.072e-15, No Iterations 2 smoothSolver: Solving for Uy, Initial residual = 1.904e-06, Final residual = 3.012e-17, No Iterations 2 smoothSolver: Solving for Uz, Initial residual = 1.891e-06, Final residual = 3.097e-17, No Iterations 2 diagonal: Solving for rhoE, Initial residual = 0, Final residual = 0, No Iterations 0 smoothSolver: Solving for e, Initial residual = 7.404e-07, Final residual = 1.87e-16, No Iterations 2 smoothSolver: Solving for omega, Initial residual = 7.563e-06, Final residual = 5.029e-12, No Iterations 2 bounding omega, min: -641.6 max: 1.004e+06 average: 3.899e+04 smoothSolver: Solving for k, Initial residual = 1.925e-05, Final residual = 2.255e-12, No Iterations 2 bounding k, min: -79.06 max: 1.279e+04 average: 339.2 For omega and k, there's the bounding portion there. So are the values reasonable? Thanks. |
Display Modes | |
OpenFOAM - Validation of Results | Ahmed | OpenFOAM Running, Solving & CFD | 10 | May 13, 2018 18:28 |
running OpenFoam in parallel | vishwa | OpenFOAM Running, Solving & CFD | 22 | August 2, 2015 08:53 |
Running in parallel with a machine that doesn't have OpenFOAM | aujamal20 | OpenFOAM Running, Solving & CFD | 1 | September 14, 2013 10:08 |
Diffent Results between OpenFOAM and Fluent | biau | OpenFOAM Running, Solving & CFD | 10 | July 15, 2013 09:31 |
Random machine freezes when running several OpenFoam jobs simultaneously | 2bias | OpenFOAM Installation | 5 | July 2, 2010 07:40 |
