[groovyBC]Change alpha.water and velocities during Run in pipe |
November 24, 2017, 03:34 |
Oliver K
Rep Power: 8 |
Hey,
My Problem is as followed: I've got a pipe with an inflowing fluid (water). I want to change with groovyBC the area of the inflow and the inflow velocity of the patch during the run on a time dependency. Actually it's a "closing" of the inlet, so the area of my inflow is reduced over the time, but my flow rate needs to be constant so the velocity has to speed up. I tried to make it more understandable with a drawing: So my guess is to put the patches of the inflow in alpha.water and U with a groovyBC. Because of the circularity it's a bit difficult to do, but I think the definition in U could be right. My main problem is the definition of my alpha.water. (actually I analyze the flow in both ways so my inflow is on patch outlet) What I tried so far: I made a dependency that on the patch outlet in alpha.water that every cell value between 0.5 and 1.1 should be used for my field U. alpha.water Code:
outlet { type groovyBC; variables "Oberkante=-1751.518895;Unterkante=-1765.558895;close=pos().z-0-(14.04*time()*1.0);"; valueExpression "(pos().z < close) ? 1 : 0"; factionExpression "(pos().z < close) ? 1 : 0"; value uniform 1; U Code:
type groovyBC; value uniform (0 0 0); aliases {alphaWater alpha.water;}; variables "alphaFromPatchOutlet{outlet}=alphaWater;neededPatchArea=alphaFromPatchOutlet*min(0.5,2);aHight=(0.001/((4/3)*14.04*time()*1.0*sqrt(2*7.02*14.04*time()*1.0-pow(14.04*time()*1.0,2))));"; valueExpression "-normal()*aHight*alphaFromPatchOutlet"; For now the main problem is the definition of alpha.water for the patch outlet. Does anyone have a guess where the Problem in the definition could be? Many thanks in advance, Oli |
November 28, 2022, 03:54 |
#2 | |
HR
Rep Power: 3 |
Hi did you manage to run the simulation with this condition ? I am looking at a similar situation where I want my inlet patch to pulsate alpha where the inlet produces gases for sometime and then produces no gas. |
interFoam two-phase pipe flow air phase behaviour | katete | OpenFOAM Running, Solving & CFD | 11 | February 3, 2021 03:14 |
LES of pipe flows: wall normal velocities not zero | Dan1788 | OpenFOAM Running, Solving & CFD | 0 | December 16, 2014 22:05 |
Water pipe - pressure inlet/outlet - unrealistic velocities | erichu | OpenFOAM Running, Solving & CFD | 1 | April 11, 2013 07:08 |
Strange Behavior of A Mesh Run at Two Dfferent Velocities Using Turbulence Model | zachnap | Main CFD Forum | 0 | May 11, 2011 15:22 |
Poiseuille flow (flow in a pipe) in SOLA-VOF. Parabolic distribution of velocities. | Anton | Main CFD Forum | 9 | April 29, 2009 10:31 |
