modify scalarTransportFoam, problems need help
Dear all.
I want to modify the salarTransportFoam to solve another problems.The code like this: fvScalarMatrix VaEqn ( - fvm::laplacian(Per, Va) == F*(Z1*C1+Z2*C2) ); The fvSchemes file like this: ddtSchemes { default Euler; } gradSchemes { default Gauss linear; } divSchemes { default Gauss linear; } laplacianSchemes { default none; laplacian(Per, Va) Gauss linear corrected; } interpolationSchemes { default linear; } snGradSchemes { default corrected; } when runing ,it displayed the following mistake: "ill defined primitiveEntry starting at keyword 'laplacian(Per,' on line 36 and ending at line 57" From function void Foam::primitiveEntry::readEntry(const Foam::dictionary&, Foam::Istream&) in file db/dictionary/primitiveEntry/primitiveEntryIO.C at line 189. I need help very much. Thank you very much. |
