buoyantSimpleFoam with equationOfState rhoConst crashes
I wanted to calculate the hydrodynamics and heat transfer of a stirred tank with the buoyantSimpleFoam solver. For this i merged the cases of buoyantCavity and mixerVessel2D with a MRF for the rotor of the stirred tank. If I am using the equationOfState perfectGas it is working fine and I get the velocity and temperature field. Now I wanted to use the equationOfState rhoConst and therefore changed my thermophysicalProperties-file like this: thermoType { type heRhoThermo; mixture pureMixture; transport const; thermo hConst; equationOfState rhoConst; specie specie; energy sensibleEnthalpy; } In addition I inserted rho: equationOfState { rho 10; } If I start the solver now I get the following error in the laminar and turbulent case: Starting time loop Time = 1 DILUPBiCG: Solving for h, Initial residual = 1, Final residual = 0.00404327, No Iterations 1 GAMG: Solving for p_rgh, Initial residual = 0.996177, Final residual = 0.00740903, No Iterations 5 time step continuity errors : sum local = 2.42478, global = -7.73459e-15, cumulative = -7.73459e-15 #0 Foam::error::printStack(Foam::Ostream&) at ??:? #1 Foam::sigFpe::sigHandler(int) at ??:? #2 in "/lib64/libc.so.6" #3 Foam::dimensioned<double> Foam::operator/<double>(Foam::dimensioned<double> const&, Foam::dimensioned<double> const&) at ??:? #4 at ??:? #5 __libc_start_main in "/lib64/libc.so.6" #6 at ??:? Floating point exception gott@master:~/OpenFOAM/gott-2.3.x/run/buoyantCavity> ICE default IO error handler doing an exit(), pid = 240390, errno = 11 Why is my simulation crashing? Is it not possible to use the equationOfState rhoConst with the buoyantSimpleFoam-Solver? Or how can i calculate with an incompressible fluid a heated stirred tank else? Help is really appreciated :) I trust in your knowledge, kind regards, Michael |
After some research i found the answer myself. I used OF2.3.x and there is a bug in the source code. In the pEqn.H at the end you find this:
if (closedVolume) { p += (initialMass - fvc::domainIntegrate(psi*p)) /fvc::domainIntegrate(psi); p_rgh = p - rho*gh; } For incompressible equations of state the compressibility psi is zero and therefore you get an error for closed volumes. The bug is already corrected in the new OF5. if (!thermo.incompressible() && closedVolume) { p += (initialMass - fvc::domainIntegrate(psi*p)) /fvc::domainIntegrate(psi); p_rgh = p - rho*gh; } With the additional condition !thermo.incompressible() you are not entering the loop for incompressible flows. Michael |
