Chen Sihe
Rep Power: 9 ![]() |
Hi all, I am doing a two-phase simulation with twoPhaseEulerFoam recently. However, there is a problem that the behavior of particles at the inlet is quite strange. I have attached my plottings of the problem in the thread. In the picture, the x-axis indicates the axial position (axis parallel to initial particle velocity) in m, and the y-axis indicates the axial velocity in m/s
The thing is that, the velocity of the particles is set to be around 3.4m/s at the inlet, but it quickly drops to around 1.5m/s for some unknown reason; after that, it is brought back to around 2m/s by the air (quite possibly). Now the problem is that I don't know why the velocity is brought down so quickly. Has anyone got any ideas? Thanks a lot guys ![]() |
Chen Sihe
One interesting discovery/update is that, I have tried to modify many of the physical quantities, and found that if I change the volume fraction to a larger value, it seems that things go well and the behaviors are relatively good. How can this happen? I am quite confused.
Taher Chegini
Rep Power: 13 ![]() |
You didn't provide any details about the way you setup your case but I go out on a limb and say that it might be due to your mesh size since your get a better result with larger alpha. Did you conduct a mesh convergence study?
Display Modes | |
Sharing links for two phase solver packages developed by openfoam community | swap_9068 | OpenFOAM Programming & Development | 1 | April 2, 2017 06:43 |
Gravity/Buoyancy/Buoyancy reference density in two phase flow | sharifi | CFX | 10 | June 9, 2014 11:23 |
Derive fixed number of phase from clone () in multiphaseEulerFoam Solver | Aj Nair | OpenFOAM Programming & Development | 0 | December 16, 2013 21:41 |
Definition of continuous phase Reynolds number | gaurav_bhutani | Main CFD Forum | 0 | November 8, 2013 11:31 |
two Phase column simulation | chemeng | OpenFOAM | 3 | August 18, 2010 13:53 |
