linnemann |
January 5, 2018 02:38 |
chtMultiRegionSimpleFoam probes multiple output
Hi
I cannot find if it is a bug or a feature but in my chtMultiRegionSimpleFoam case here https://github.com/nelinnemann/of-ca...oldplateCooler
I have the following entry in controlDict
functions
probes
// Where to load it from
functionObjectLibs ( "libsampling.so" );
type probes;
// Name of the directory for probe data
name probes;
region solid;
// Write at same frequency as fields
writeControl timeStep;
writeInterval 1;
// Fields to be probed
fields
T
probeLocations
( 0.05 0.02 0.075 ) // beginning of solid fin
( 0.15 0.02 0.075 ) // middle of solid fin
( 0.225 0.02 0.075 ) // end of solid fin
What i do not understand is that for each timestep i get 3 lines of output.
# Probe 0 (0.05 0.02 0.075)
# Probe 1 (0.15 0.02 0.075)
# Probe 2 (0.225 0.02 0.075)
# Probe 0 1 2
# Time
1 499.7919 499.9373 499.9437
2 499.4074 499.8084 499.8277
3 498.9954 499.6587 499.6925
EDIT:
Just tried with the multiRegionHeaterRadiation tutorial from official OpenFOAM-dev.
Same result, writing the values 3 times.
EDIT2:
Tried with pipeCyclic case and simpleFoam solver. Here everything is fine, seems like a multiregion issue.
