Foam::divide, transient conjugate heat transfer
1 Attachment(s)
Hello foamers, I am trying to simulate transient conjugate heat transfer inside a cylinder and to the air. When I type chtMultiRegionFoam on the command window I get this error. Dictionaries are uploaded. Any help will be appreciated. Thank you very much.
--> FOAM Warning : From function virtual void Foam::probes::findElements(const Foam::fvMesh&) in file probes/probes.C at line 122 Did not find location (0.7 0.8 0.25) in any cell. Skipping location. Region: fluid Courant Number mean: 5.294362 max: 509.8198 Region: solid Diffusion Number mean: 401.0293 max: 16244.76 Time = 1 Solving for fluid region fluid Program received signal SIGFPE, Arithmetic exception. 0x00007ffff24ca208 in Foam::divide(Foam::Field<double>&, Foam::UList<double> const&, Foam::UList<double> const&) () from /home/user2/OpenFOAM-v1706/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so (gdb) backtrace #0 0x00007ffff24ca208 in Foam::divide(Foam::Field<double>&, Foam::UList<double> const&, Foam::UList<double> const&) () from /home/user2/OpenFOAM-v1706/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so #1 0x00007ffff24cbf64 in Foam::operator/(Foam::UList<double> const&, Foam::UList<double> const&) () from /home/user2/OpenFOAM-v1706/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so #2 0x00007ffff2318e84 in Foam::diagonalSolver::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const () from /home/user2/OpenFOAM-v1706/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so #3 0x00007ffff480e41e in Foam::fvMatrix<double>::solveSegregated(Foam::dict ionary const&) () from /home/user2/OpenFOAM-v1706/platforms/linux64GccDPInt32Opt/lib/libfiniteVolume.so #4 0x00007ffff434b467 in Foam::fvMatrix<double>::solveSegregatedOrCoupled(F oam::dictionary const&) () from /home/user2/OpenFOAM-v1706/platforms/linux64GccDPInt32Opt/lib/libfiniteVolume.so #5 0x00007ffff43116af in Foam::fvMesh::solve(Foam::fvMatrix<double>&, Foam::dictionary const&) const () from /home/user2/OpenFOAM-v1706/platforms/linux64GccDPInt32Opt/lib/libfiniteVolume.so #6 0x000000000046ebdf in Foam::fvMatrix<double>::solve() () #7 0x000000000043f716 in main () |
1 Attachment(s)
Hello Cagatayemre!
Where is your heat source? Why you are using chtMultiRegionFoam? There is just one region in the example you uploaded! Usually you need at least one region as a fluid and one as solid to use chtMultiRegion(Simple)Foam. Please tell The heat source or which surface has which temperature... Why you are using the solver potetialFoam in your example? As I understood you want to use chtMultiRegionFoam! You need to change the solver (application) in controlDict to chtMultiRegionFoam! There is no T dictionary in your 0.orig folder... This needs to be defined if you are running a conjugate heat transfer! Here is an example for chtMultiRegionSimpleFoam with heat source in region LED! Regards Peter |
1 Attachment(s)
Here is an example like your case!
Heat source is in SOURCE! fvOptions! Regards Peter |
1 Attachment(s)
Sorry Peter, I just uploaded a wrong file. This is the correct file. And thank you for the test file. I am new to OpenFOAM. By the way, I did look at these topics and I just changed the diameter of the cylinder and add PIMPLE solver. I used Sandymech's dictionaries. I didnt use yours because you did with snappyHexMesh. but I need to change the diameter and length of the cylinder.
p { margin-bottom: 0.1in; line-height: 120%; }a:link { } https://www.cfd-online.com/Forums/op...t-transfe.html https://www.cfd-online.com/Forums/openfoam-solving/191550-conjugate-heat-transfer-heat-generating-cylinder-natural-convection.html |
1 Attachment(s)
Hello Cagatayemre!
In your case (the last one you sent!) you need to change the file fvSolutions in your system/fluid with one that solve a simple instead of pimple! Take simply the file in my example LUM from system/INNEN/fvSolutions and replace it in your case. Then the simulation (yours) will run! Anyway, you will have a divergence after 3 itterations :) Somthing still going wrong here... The temperature field is exploding... Decreasing the relaxationFaktors of h to 0.7 (for fluid) will let your case works fine! Regards Peter |
Thank you very much Peter but now I have following error. I am trying to solve it with chtMultiRegionFoam. Is it correct ? Which command should I type? I use
blockMesh -region solid blockMesh -region fluid changeDictionary - region solid changeDictionary - region fluid chtMultiRegionFoam keyword PIMPLE is undefined in dictionary "/home/user2/OpenFOAM-v1706/tutorials/OpenFoamRunFiles/flowAroundHeatedCylinder/cylnatural_send4/system/fluid/fvSolution" file: /home/user2/OpenFOAM-v1706/tutorials/OpenFoamRunFiles/flowAroundHeatedCylinder/cylnatural_send4/system/fluid/fvSolution from line 21 to line 60. Quote:
1 Attachment(s)
Sure it will not work! All setups are made for chtMultiRegionSimpleFoam!
To do that you need to do the following: - Replace your controlDict with the one in: ../tutorials/heatTransfer/chtMultiRegionFoam/multiRegionHeater/system/ - Replace: fvSolution and fvSchemes for both solid and fluid with those in: ../tutorials/heatTransfer/chtMultiRegionFoam/multiRegionHeater/system/heater/ and ,,/tutorials/heatTransfer/chtMultiRegionFoam/multiRegionHeater/system/bottomWater/ Then it will work :) Regards Peter |
Thank you very much Peter. Now it iterates without any error. I dont know how can I give a reputation point for you. Where is the button do you know?
