Mike Tree
Rep Power: 11 ![]() |
I am attempting to run the waveExampleStokesI tutorial as found in $FOAM_TUTORIALS/multiphase/interFoam/laminar/, but I find that it crashes after a certain number of iterations. I, literally, copied the waveExampleStokesI folder to different location and ran ./Allrun. The following is my interFoam log file:
Courant Number mean: 0.00158763 max: 0.0340732 3226 Interface Courant Number mean: 6.01934e-05 max: 0.0320865 3227 deltaT = 0.011 3228 Time = 1.507 3229 3230 PIMPLE: iteration 1 3231 Updating StokesI wave model for patch inlet 3232 MULES: Solving for alpha.water 3233 Phase-1 volume fraction = 0.799092 Min(alpha.water) = 0 Max(alpha.water) = 1.00034 3234 Updating StokesI wave model for patch inlet 3235 MULES: Solving for alpha.water 3236 Phase-1 volume fraction = 0.799092 Min(alpha.water) = 0 Max(alpha.water) = 1.00034 3237 Updating StokesI wave model for patch inlet 3238 MULES: Solving for alpha.water 3239 Phase-1 volume fraction = 0.799092 Min(alpha.water) = 0 Max(alpha.water) = 1.00034 3240 Updating StokesI wave model for patch inlet 3241 Updating shallowWaterAbsorption wave model for patch outlet 3242 DICPCG: Solving for p_rgh, Initial residual = 0.000225289, Final residual = 2.40448e-07, No Iterations 1 3243 time step continuity errors : sum local = 9.98073e-05, global = -3.22236e-06, cumulative = -0.000427985 3244 GAMG: Solving for p_rgh, Initial residual = 2.42072e-07, Final residual = 1.53015e-08, No Iterations 1 3245 time step continuity errors : sum local = 6.3507e-06, global = -2.53562e-06, cumulative = -0.00043052 3246 ExecutionTime = 20.29 s ClockTime = 23 s 3247 3248 Courant Number mean: 0.0016059 max: 0.0344237 3249 Interface Courant Number mean: 6.14736e-05 max: 0.0321527 3250 deltaT = 0.011 3251 Time = 1.518 3252 3253 PIMPLE: iteration 1 3254 Updating StokesI wave model for patch inlet 3255 MULES: Solving for alpha.water 3256 Phase-1 volume fraction = 0.799093 Min(alpha.water) = 0 Max(alpha.water) = 1.00034 3257 Updating StokesI wave model for patch inlet 3258 MULES: Solving for alpha.water 3259 Phase-1 volume fraction = 0.799093 Min(alpha.water) = 0 Max(alpha.water) = 1.00034 3260 Updating StokesI wave model for patch inlet 3261 [0] #0 Foam::error::printStack(Foam::Ostream&) in "/opt/Software/openfoam/1612+/OpenFOAM-v1612+/platforms/linux64IccDPInt32Opt/lib/libOpenFOAM.so" 3262 [0] #1 Foam::sigFpe::sigHandler(int) in "/opt/Software/openfoam/1612+/OpenFOAM-v1612+/platforms/linux64IccDPInt32Opt/lib/libOpenFOAM.so" 3263 [0] #2 ? in "/lib64/libc.so.6" 3264 [0] #3 Foam::waveModel::correct(double) in "/opt/Software/openfoam/1612+/OpenFOAM-v1612+/platforms/linux64IccDPInt32Opt/lib/libwaveModels.so" 3265 [0] #4 Foam::waveAlphaFvPatchScalarField::updateCoeffs() in "/opt/Software/openfoam/1612+/OpenFOAM-v1612+/platforms/linux64IccDPInt32Opt/lib/libwaveModels.so" 3266 [0] #5 Foam::fvPatchField<double>::evaluate(Foam::UPstream::commsTypes) in "/opt/Software/openfoam/1612+/OpenFOAM-v1612+/platforms/linux64IccDPInt32Opt/bin/interFoam" 3267 [0] #6 Foam::MULES::explicitSolve(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::GeometricField<double, Fo am::fvsPatchField, Foam::surfaceMesh>&, double, double) in "/opt/Software/openfoam/1612+/OpenFOAM-v1612+/platforms/linux64IccDPInt32Opt/lib/libfiniteVolume.so" 3268 [0] #7 ? in "/opt/Software/openfoam/1612+/OpenFOAM-v1612+/platforms/linux64IccDPInt32Opt/bin/interFoam" 3269 [0] #8 __libc_start_main in "/lib64/libc.so.6" 3270 [0] #9 ? in "/opt/Software/openfoam/1612+/OpenFOAM-v1612+/platforms/linux64IccDPInt32Opt/bin/interFoam" Any help will be most appreciated. |
Display Modes | |
tutorial files | KITetima | FLUENT | 8 | November 23, 2019 16:05 |
AMI - Propeller Tutorial diverging | kingmaker | OpenFOAM Running, Solving & CFD | 2 | November 4, 2016 02:57 |
Problem on Fluent Tutorial: Horizontal Film Boilig | Feng | FLUENT | 2 | April 13, 2013 05:34 |
[Virtualization] OpenFOAM oriented tutorial on using VMware Player - support thread | wyldckat | OpenFOAM Installation | 2 | July 11, 2012 16:01 |
tutorial 6 in Fluent 6.2 tutorial and Mesh | pilli4u | FLUENT | 2 | April 2, 2007 05:09 |
