Christian
Rep Power: 0 ![]() |
Hello everyone,
i am trying to run my case in parallel using Unbuntu 16.04 in a VM under Windows 10. In the VM options i've allocated 6 processors to my vm (got a ryzen 5 1600x). If i check this with lscpu under ubuntu, it says that i am indeed using 6 cpus, so that works. To run my case in parallel, i've decomposed it using decomposePar and it correctly creates the folders processor0 - processor5. Now i try to run my simulation in parallel typing: mpirun -np 6 pimpleFoam -parallel > log & The simulation starts, but if i monitor my CPU usage using htop, it always shows only one CPU at 100% and also only one pimpleFoam process is listed. What am i doing wrong? Any help is greatly appreciated. Many thanks. |
Display Modes | |
error while running in parallel using openmpi on local mc 6 processors | suryawanshi_nitin | OpenFOAM | 10 | February 22, 2017 21:33 |
Fluent 14.0 file not running in parallel mode in cluster | tejakalva | FLUENT | 0 | February 4, 2015 07:02 |
Problems running in parallel - missing controlDict | Argen | OpenFOAM Running, Solving & CFD | 4 | June 7, 2012 03:50 |
Statically Compiling OpenFOAM Issues | herzfeldd | OpenFOAM Installation | 21 | January 6, 2009 09:38 |
Kubuntu uses dash breaks All scripts in tutorials | platopus | OpenFOAM Bugs | 8 | April 15, 2008 07:52 |
