roof boundary condition not acting like atmosphere
Old   October 8, 2022, 16:48
Default roof boundary condition not acting like atmosphere
Josh McCraney
joshmccraney is on a distinguished road
Hi everyone
I am running OpenFOAM 6, interFoam. I am trying to have an atmospheric boundary condition on the roof (like the dambreak tutorial) of the attached image. Gas is blue, liquid is red. As you can see, liquid is wicking into the roof corners (this is a very small geometry, so water overcomes gravity and does this). But I want the roof to be atmospheric, which is why I have set the 0 directory as shown
alpha.water.orig
internalField   uniform 0;//initially air in the entire domain - we will change that with setFields!
boundaryField
    tank
        type            constantAlphaContactAngle;
	theta0		0;
	limit		gradient;
	value		uniform 0;
    roof
//    This boundary condition provides a generic outflow condition, with
//    specified inflow for the case of return flow.
//    The mode of operation is determined by the sign of the flux across the
//    patch faces.
        type            inletOutlet;
        inletValue      uniform 0;
        value           uniform 0;
    outlet
        type            inletOutlet;
        inletValue      uniform 1;
        value           uniform 1;
    inlet
        type            fixedValue;
        value           uniform 1;//only liquid enters the domain
    symm_side
        type            symmetry;
p_rgh:
boundaryField
    tank
        type            fixedFluxPressure;
        value           uniform 0;
    roof
        type            totalPressure;
        p0              uniform 0;
    outlet
        type            totalPressure;
        p0              uniform 0;
	//type		fixedValue;
	//value		uniform 0;
    inlet
        value           uniform 0;
    symm_side
        type            symmetry;
U:
boundaryField
    tank
        type            noSlip;			//no slip along the walls - replaces fixedValue with uniform (0 0 0)
    roof
	type		pressureInletOutletVelocity;
	value		uniform (0 0 0);
    outlet
  inlet
      type         uniformFixedValue;
      uniformValue    table
           (0   	(0 0 0.0149))
           (10   	(0 0 0.0149))
    symm_side
        type            symmetry;
Any help is greatly appreciated!
Nevermind, issue was in my blockMeshDict
joshmccraney is offline   Reply With Quote
sliding mesh problem in CFX Saima CFX 46 September 11, 2021 07:38
Basic Nozzle-Expander Design karmavatar CFX 20 March 20, 2016 08:44
Radiation interface hinca CFX 15 January 26, 2014 17:11
CFX fails to calculate a diffuser pipe flow shenying0710 CFX 7 March 26, 2013 04:13
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 15:55
