Foam::error::PrintStack error while running rhoPorousSimpleFoam in OF 2.4.0 |
January 23, 2018, 08:41 |
Deep
Rep Power: 8 |
I'm running a case based on the angledDuctImplicit tutorial. But I'm getting following error even before the iterations start. Code:
#0 Foam::error::printStack(Foam::Ostream&) at ??:? #1 Foam::sigFpe::sigHandler(int) at ??:? #2 ? in "/lib/x86_64-linux-gnu/libc.so.6" #3 Foam::heRhoThermo<Foam::rhoThermo, Foam::pureMixture<Foam::sutherlandTransport<Foam::species::thermo<Foam::hConstThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleEnthalpy> > > >::calculate() at ??:? #4 Foam::rhoThermo::addfvMeshConstructorToTable<Foam::heRhoThermo<Foam::rhoThermo, Foam::pureMixture<Foam::sutherlandTransport<Foam::species::thermo<Foam::hConstThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleEnthalpy> > > > >::New(Foam::fvMesh const&, Foam::word const&) at ??:? #5 Foam::autoPtr<Foam::rhoThermo> Foam::basicThermo::New<Foam::rhoThermo>(Foam::fvMesh const&, Foam::word const&) at ??:? #6 Foam::rhoThermo::New(Foam::fvMesh const&, Foam::word const&) at ??:? #7 ? at ??:? #8 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" #9 ? at ??:? Floating point exception (core dumped) The thrmoPhysicalProperties disctionary looks as below: Code:
FoamFile { version 2.0; format ascii; class dictionary; location "constant"; object thermophysicalProperties; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // thermoType { type heRhoThermo; mixture pureMixture; transport sutherland;//const; thermo hConst; equationOfState perfectGas; specie specie; energy sensibleInternalEnergy;//sensibleEnthalpy; } mixture { specie { nMoles 1; molWeight 28.9; } thermodynamics { Cp 1005; Hf 0;//2.544e+06;//0; } transport { //mu 1.8e-05; //Pr 0.7; As 1.4792e-06; Ts 116; } } |
January 24, 2018, 09:02 |
Tobias Holzmann
Rep Power: 51 |
Hi, a floating point exception in that particular case is given by division with zero. Can you please give more information such as the log file (before the error occur) in order to identify the problem?
By the way, why you stick to an very old version of FOAM? 2.4. is almost outdated and you would have much better features in the latest version.
Keep foaming, Tobias Holzmann |
January 24, 2018, 12:02 |
#3 | |
Deep
Rep Power: 8 |
Unfortunately I made some changes since I started this thread, so I can't give you the part of the log before the error. However, I did try to run the case in latest version of OF as well and I get different errors. I am using 2.4.0-MNF version because I want to use one of the solvers which has not been integrated in the updated form yet into the regular release. But this is at a later stage. For rhoPorousSimpleFoam I definitely can use 5.0 and I did. Now, the errors am now getting are different and not much help from related existing threads. I get different errors for 5.0 (after making relevant additions/changes according to structural changes in files or syntaxes) and 2.4.0. I'll include both here: OF2.4.0 Error: Code:
Create time Create mesh for time = 0 SIMPLE: convergence criteria field p tolerance 0.001 field U tolerance 0.0001 field e tolerance 0.001 field "(k|epsilon|omega)" tolerance 0.001 Reading thermophysical properties Selecting thermodynamics package { type heRhoThermo; mixture pureMixture; transport sutherland; thermo hConst; equationOfState perfectGas; specie specie; energy sensibleInternalEnergy; } Reading field U Reading/calculating face flux field phi Creating turbulence model Selecting RAS turbulence model kEpsilon kEpsilonCoeffs { Cmu 0.09; C1 1.44; C2 1.92; C3 -0.33; sigmak 1; sigmaEps 1.3; Prt 1; } Creating finite volume options from "system/fvOptions" Selecting finite volume options model type fixedTemperatureConstraint Source: source1 - applying source for all time - selecting cells using cellZone porouszone - selected 8000 cell(s) with volume 0.0001 Creating porosity model list from porosityProperties Porosity region porosity1: selecting model: DarcyForchheimer creating porous zone: porouszone Using pressure implicit porosity Starting time loop Time = 1 --> FOAM FATAL ERROR: gradientInternalCoeffs cannot be called for a calculatedFvPatchField on patch outletExt of field e in file "/home/ywb17176/OpenFOAM/zProjects/x1/0/e" You are probably trying to solve for a field with a default boundary condition. From function calculatedFvPatchField<Type>::gradientInternalCoeffs() const in file fields/fvPatchFields/basic/calculated/calculatedFvPatchField.C at line 199. FOAM exiting OF5.0 Error: Code:
Create time Create mesh for time = 0 SIMPLE: convergence criteria field p tolerance 0.001 field U tolerance 0.0001 field e tolerance 0.001 field "(k|epsilon|omega)" tolerance 0.001 Reading thermophysical properties Selecting thermodynamics package { type heRhoThermo; mixture pureMixture; transport sutherland; thermo hConst; equationOfState perfectGas; specie specie; energy sensibleInternalEnergy; } Reading field U Reading/calculating face flux field phi --> FOAM Warning : From function Foam::pressureControl::pressureControl(const volScalarField&, const volScalarField&, const Foam::dictionary&, bool) in file cfdTools/general/pressureControl/pressureControl.C at line 125 Reading "/home/ywb17176/OpenFOAM/zProjects/x/system/fvSolution.SIMPLE" from line 52 to line 64 'rhoMax' specified rather than 'pMax' or 'pMaxFactor' This is supported for backward-compatibility but 'pMax' or 'pMaxFactor' are more reliable. --> FOAM Warning : From function Foam::pressureControl::pressureControl(const volScalarField&, const volScalarField&, const Foam::dictionary&, bool) in file cfdTools/general/pressureControl/pressureControl.C at line 182 Reading "/home/ywb17176/OpenFOAM/zProjects/x/system/fvSolution.SIMPLE" from line 52 to line 64 'rhoMin' specified rather than 'pMin' or 'pMinFactor' This is supported for backward-compatibility but'pMin' or 'pMinFactor' are more reliable. pressureControl pMax 2e+06 pMin 28050.5 Creating turbulence model Selecting turbulence model type RAS Selecting RAS turbulence model kEpsilon RAS { RASModel kEpsilon; turbulence on; printCoeffs on; Cmu 0.09; C1 1.44; C2 1.92; C3 0; sigmak 1; sigmaEps 1.3; } No MRF models present Creating finite volume options from "system/fvOptions" Selecting finite volume options model type fixedTemperatureConstraint Source: source1 --> FOAM FATAL IO ERROR: keyword selectionMode is undefined in dictionary "/home/ywb17176/OpenFOAM/zProjects/x/system/fvOptions.source1.fixedTemperatureConstraintCoeffs" file: /home/ywb17176/OpenFOAM/zProjects/x/system/fvOptions.source1.fixedTemperatureConstraintCoeffs from line 27 to line 28. From function const Foam::entry& Foam::dictionary::lookupEntry(const Foam::word&, bool, bool) const in file db/dictionary/dictionary.C at line 566. FOAM exiting Code:
source1 { type fixedTemperatureConstraint; active true; selectionMode cellZone; cellZone porouszone; fixedTemperatureConstraintCoeffs { mode uniform; temperature 350; } } fvOptions does seem to have the selectionMode defined. So I've no clue. |
January 24, 2018, 15:20 |
Tobias Holzmann
Rep Power: 51 |
for 5.x the error message tells you what is missing: Code:
keyword selectionMode is undefined in dictionary "/home/ywb17176/OpenFOAM/zProjects/x/system/fvOptions.source1.fixedTemperatureConstraintCoeffs" Code:
source1 { type fixedTemperatureConstraint; active true; fixedTemperatureConstraintCoeffs { mode uniform; temperature 350; selectionMode cellZone; cellZone porouszone; } }
January 25, 2018, 08:52 |
#5 | |
Deep
Rep Power: 8 |
This seems to have worked. But now this is what I get for OF 5.x: Code:
Create time Create mesh for time = 0 SIMPLE: convergence criteria field p tolerance 0.001 field U tolerance 0.0001 field e tolerance 0.001 field "(k|epsilon|omega)" tolerance 0.001 Reading thermophysical properties Selecting thermodynamics package { type heRhoThermo; mixture pureMixture; transport sutherland; thermo hConst; equationOfState perfectGas; specie specie; energy sensibleInternalEnergy; } Reading field U Reading/calculating face flux field phi --> FOAM Warning : From function Foam::pressureControl::pressureControl(const volScalarField&, const volScalarField&, const Foam::dictionary&, bool) in file cfdTools/general/pressureControl/pressureControl.C at line 125 Reading "/home/ywb17176/OpenFOAM/zProjects/x/system/fvSolution.SIMPLE" from line 52 to line 64 'rhoMax' specified rather than 'pMax' or 'pMaxFactor' This is supported for backward-compatibility but 'pMax' or 'pMaxFactor' are more reliable. --> FOAM Warning : From function Foam::pressureControl::pressureControl(const volScalarField&, const volScalarField&, const Foam::dictionary&, bool) in file cfdTools/general/pressureControl/pressureControl.C at line 182 Reading "/home/ywb17176/OpenFOAM/zProjects/x/system/fvSolution.SIMPLE" from line 52 to line 64 'rhoMin' specified rather than 'pMin' or 'pMinFactor' This is supported for backward-compatibility but'pMin' or 'pMinFactor' are more reliable. pressureControl pMax 2e+06 pMin 28050.5 Creating turbulence model Selecting turbulence model type RAS Selecting RAS turbulence model kEpsilon RAS { RASModel kEpsilon; turbulence on; printCoeffs on; Cmu 0.09; C1 1.44; C2 1.92; C3 0; sigmak 1; sigmaEps 1.3; } No MRF models present Creating finite volume options from "system/fvOptions" Selecting finite volume options model type fixedTemperatureConstraint Source: source1 - selecting cells using cellZone porouszone - selected 8000 cell(s) with volume 0.0001 Creating porosity model list from porosityProperties Porosity region porosity1: selecting model: DarcyForchheimer creating porous zone: porouszone Using pressure implicit porosity Starting time loop Time = 1 --> FOAM FATAL IO ERROR: keyword div(((rho*nuEff)*dev2(T(grad(U))))) is undefined in dictionary "/home/ywb17176/OpenFOAM/zProjects/x/system/fvSchemes.divSchemes" file: /home/ywb17176/OpenFOAM/zProjects/x/system/fvSchemes.divSchemes from line 30 to line 36. From function const Foam::entry& Foam::dictionary::lookupEntry(const Foam::word&, bool, bool) const in file db/dictionary/dictionary.C at line 566. FOAM exiting Code:
divSchemes { div(phi,U) bounded Gauss upwind; // div((muEff*dev2(T(grad(U))))) Gauss linear; div((nuEff*dev2(T(grad(U))))) Gauss linear; div(phi,e) bounded Gauss upwind; div(phi,epsilon) bounded Gauss upwind; div(phi,k) bounded Gauss upwind; div(phi,Ekp) bounded Gauss upwind; } Also what about those warnings ? |
January 25, 2018, 09:03 |
#6 | |
Tobias Holzmann
Rep Power: 51 |
Again, the solver tells you what is missing:
div(((rho*nuEff)*dev2(T(grad(U))))) Code:
div((nuEff*dev2(T(grad(U))))) Quote:
January 25, 2018, 10:05 |
#7 | |
Deep
Rep Power: 8 |
Create time Create mesh for time = 0 SIMPLE: convergence criteria field p tolerance 0.001 field U tolerance 0.0001 field e tolerance 0.001 field "(k|epsilon|omega)" tolerance 0.001 Reading thermophysical properties Selecting thermodynamics package { type heRhoThermo; mixture pureMixture; transport sutherland; thermo hConst; equationOfState perfectGas; specie specie; energy sensibleInternalEnergy; } Reading field U Reading/calculating face flux field phi --> FOAM Warning : From function Foam::pressureControl::pressureControl(const volScalarField&, const volScalarField&, const Foam::dictionary&, bool) in file cfdTools/general/pressureControl/pressureControl.C at line 125 Reading "/home/ywb17176/OpenFOAM/zProjects/x/system/fvSolution.SIMPLE" from line 52 to line 64 'rhoMax' specified rather than 'pMax' or 'pMaxFactor' This is supported for backward-compatibility but 'pMax' or 'pMaxFactor' are more reliable. --> FOAM Warning : From function Foam::pressureControl::pressureControl(const volScalarField&, const volScalarField&, const Foam::dictionary&, bool) in file cfdTools/general/pressureControl/pressureControl.C at line 182 Reading "/home/ywb17176/OpenFOAM/zProjects/x/system/fvSolution.SIMPLE" from line 52 to line 64 'rhoMin' specified rather than 'pMin' or 'pMinFactor' This is supported for backward-compatibility but'pMin' or 'pMinFactor' are more reliable. pressureControl pMax 2e+06 pMin 28050.5 Creating turbulence model Selecting turbulence model type RAS Selecting RAS turbulence model kEpsilon RAS { RASModel kEpsilon; turbulence on; printCoeffs on; Cmu 0.09; C1 1.44; C2 1.92; C3 0; sigmak 1; sigmaEps 1.3; } No MRF models present Creating finite volume options from "system/fvOptions" Selecting finite volume options model type fixedTemperatureConstraint Source: source1 - selecting cells using cellZone porouszone - selected 8000 cell(s) with volume 0.0001 Creating porosity model list from porosityProperties Porosity region porosity1: selecting model: DarcyForchheimer creating porous zone: porouszone Using pressure implicit porosity Starting time loop Time = 1 --> FOAM FATAL ERROR: cannot be called for a calculatedFvPatchField on patch outletExt of field e in file "/home/ywb17176/OpenFOAM/zProjects/x/0/e" You are probably trying to solve for a field with a default boundary condition. From function Foam::tmp<Foam::Field<Type> > Foam::calculatedFvPatchField<Type>::gradientInternalCoeffs() const [with Type = double] in file fields/fvPatchFields/basic/calculated/calculatedFvPatchField.C at line 187. FOAM aborting #0 Foam::error::printStack(Foam::Ostream&) at ??:? #1 Foam::error::abort() at ??:? #2 Foam::calculatedFvPatchField<double>::gradientInternalCoeffs() const at ??:? #3 Foam::fv::gaussLaplacianScheme<double, Foam::SymmTensor<double> >::fvmLaplacianUncorrected(Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) at ??:? #4 Foam::fv::gaussLaplacianScheme<double, double>::fvmLaplacian(Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) at ??:? #5 Foam::fv::laplacianScheme<double, double>::fvmLaplacian(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) at ??:? #6 Foam::tmp<Foam::fvMatrix<double> > Foam::fvm::laplacian<double, double>(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::word const&) at ??:? #7 Foam::tmp<Foam::fvMatrix<double> > Foam::fvm::laplacian<double, double>(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) at ??:? #8 ? at ??:? #9 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" #10 ? at ??:? Aborted (core dumped) |
January 25, 2018, 10:12 |
Tobias Holzmann
Rep Power: 51 |
Because you solve your energy equation based on the sensible internal energy e
Therefore, I guess you have some mistakes in the temperature file. Please show your T file.
January 25, 2018, 10:15 |
#9 | |
Deep
Rep Power: 8 |
dimensions [0 0 0 1 0 0 0]; internalField uniform 195; //This includes the porous region as well, any solution? boundaryField { // front // { // type zeroGradient; // } // back // { // type zeroGradient; // } // walls // { // type zeroGradient; // } // porosityWall // { // type zeroGradient; // } inletExt { type fixedValue; value $internalField; } inletPorous { type fixedValue; value uniform 300; } outletExt { type calculated;//inletOutlet; value $internalField; //inletValue $internalField; } outletPorous { type calculated;//inletOutlet; value $internalField; //inletValue $internalField; } } |
January 25, 2018, 10:19 |
#10 |
Tobias Holzmann
Rep Power: 51 |
And here is your problem. You cannot set T to calculated. That does not make sense. If you are sitting on a patch face, just ask yourself, which other values would you use to calculate T
January 25, 2018, 10:36 |
#11 | |
Deep
Rep Power: 8 |
I had tried inletOutlet earlier. It doesn't get me anywhere, as you can see in error below: So I really want to understand how to decide which is the right BC be it T, U or p or else.. Code:
Create time Create mesh for time = 0 SIMPLE: convergence criteria field p tolerance 0.001 field U tolerance 0.0001 field e tolerance 0.001 field "(k|epsilon|omega)" tolerance 0.001 Reading thermophysical properties Selecting thermodynamics package { type heRhoThermo; mixture pureMixture; transport sutherland; thermo hConst; equationOfState perfectGas; specie specie; energy sensibleInternalEnergy; } Reading field U Reading/calculating face flux field phi --> FOAM Warning : From function Foam::pressureControl::pressureControl(const volScalarField&, const volScalarField&, const Foam::dictionary&, bool) in file cfdTools/general/pressureControl/pressureControl.C at line 125 Reading "/home/ywb17176/OpenFOAM/zProjects/x/system/fvSolution.SIMPLE" from line 52 to line 64 'rhoMax' specified rather than 'pMax' or 'pMaxFactor' This is supported for backward-compatibility but 'pMax' or 'pMaxFactor' are more reliable. --> FOAM Warning : From function Foam::pressureControl::pressureControl(const volScalarField&, const volScalarField&, const Foam::dictionary&, bool) in file cfdTools/general/pressureControl/pressureControl.C at line 182 Reading "/home/ywb17176/OpenFOAM/zProjects/x/system/fvSolution.SIMPLE" from line 52 to line 64 'rhoMin' specified rather than 'pMin' or 'pMinFactor' This is supported for backward-compatibility but'pMin' or 'pMinFactor' are more reliable. pressureControl pMax 2e+06 pMin 28050.5 Creating turbulence model Selecting turbulence model type RAS Selecting RAS turbulence model kEpsilon RAS { RASModel kEpsilon; turbulence on; printCoeffs on; Cmu 0.09; C1 1.44; C2 1.92; C3 0; sigmak 1; sigmaEps 1.3; } No MRF models present Creating finite volume options from "system/fvOptions" Selecting finite volume options model type fixedTemperatureConstraint Source: source1 - selecting cells using cellZone porouszone - selected 8000 cell(s) with volume 0.0001 Creating porosity model list from porosityProperties Porosity region porosity1: selecting model: DarcyForchheimer creating porous zone: porouszone Using pressure implicit porosity Starting time loop Time = 1 smoothSolver: Solving for e, Initial residual = 0.999866, Final residual = 6.804e-05, No Iterations 1 --> FOAM FATAL ERROR: request for volScalarField psi from objectRegistry region0 failed available objects of type volScalarField are 15 ( thermo:mu thermo:psi nut pPrevIter rho k rhoPrevIter alphat p T e thermo:rho div(phiHbyA) epsilon thermo:alpha ) From function const Type& Foam::objectRegistry::lookupObject(const Foam::word&) const [with Type = Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>] in file /home/ubuntu/OpenFOAM/OpenFOAM-5.x/src/OpenFOAM/lnInclude/objectRegistryTemplates.C at line 193. FOAM aborting #0 Foam::error::printStack(Foam::Ostream&) at ??:? #1 Foam::error::abort() at ??:? #2 Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const& Foam::objectRegistry::lookupObject<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> >(Foam::word const&) const at ??:? #3 Foam::totalPressureFvPatchScalarField::updateCoeffs(Foam::Field<double> const&, Foam::Field<Foam::Vector<double> > const&) at ??:? #4 Foam::fvMatrix<double>::fvMatrix(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::dimensionSet const&) at ??:? #5 Foam::tmp<Foam::fvMatrix<double> > Foam::fv::optionList::operator()<double>(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>&, Foam::word const&) at ??:? #6 ? at ??:? #7 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" #8 ? at ??:? Aborted (core dumped) |
January 25, 2018, 10:46 |
#12 |
Tobias Holzmann
Rep Power: 51 |
A calculated BC is used if you are calculating a field based on others; such as the p one out of p_rgh. It is calculated based on the p_rgh; thus you can use calculated:
p = p_rgh + rho*gh; And now you are mixing different topics. If you solve for e the psi field has to be there and as it seems, it is not in your register. I don't know what you are solving. If I ran a rhoPimpleFoam with the thermodynamic you set-up, I have no problems.
January 25, 2018, 10:52 |
#13 |
Deep
Rep Power: 8 |
#3 Foam::totalPressureFvPatchScalarField::updateCoeffs(Foam::Field<double> const&, Foam::Field<Foam::Vector<double> > const&) at ??:? Code:
inletExt { type zeroGradient;//totalPressure;//zeroGradient; //p0 100.0e5; } inletPorous { type zeroGradient;//totalPressure; //psi psi; //gamma 1.4; //p0 uniform 20.0e5; //value uniform 20.0e5; } outletExt { type fixedValue; value $internalField; } outletPorous { type fixedValue; value $internalField; } } The problem I am working on involves flow through and over porous material. I have purely supersonic flow around the porous material and likely subsonic flow through the porous region and I want to know temperature profiles everywhere possible. So changing the totalPressure back to zeroGradient worked. But ended up in this new printStack error after 2 iterations Code:
Creating porosity model list from porosityProperties Porosity region porosity1: selecting model: DarcyForchheimer creating porous zone: porouszone Using pressure implicit porosity Starting time loop Time = 1 smoothSolver: Solving for e, Initial residual = 0.999873, Final residual = 6.80405e-05, No Iterations 1 GAMG: Solving for p, Initial residual = 1, Final residual = 0.0439418, No Iterations 5 time step continuity errors : sum local = 4984.39, global = 1469.04, cumulative = 1469.04 pressureControl: p max 252769 smoothSolver: Solving for epsilon, Initial residual = 1, Final residual = 0.08023, No Iterations 12 smoothSolver: Solving for k, Initial residual = 1, Final residual = 0.0956772, No Iterations 12 ExecutionTime = 0.26 s ClockTime = 0 s Time = 2 smoothSolver: Solving for e, Initial residual = 0.843334, Final residual = 2.92319e-05, No Iterations 1 GAMG: Solving for p, Initial residual = 0.963382, Final residual = 0.0357441, No Iterations 7 time step continuity errors : sum local = 5466.63, global = -1295.78, cumulative = 173.256 pressureControl: p max 2.46131e+13 pressureControl: p min -2.08565e+10 smoothSolver: Solving for epsilon, Initial residual = 1, Final residual = 6.65594e-05, No Iterations 2 smoothSolver: Solving for k, Initial residual = 0.89082, Final residual = 0.038888, No Iterations 2 ExecutionTime = 0.37 s ClockTime = 0 s Time = 3 smoothSolver: Solving for e, Initial residual = 0.618771, Final residual = 0.040711, No Iterations 2 #0 Foam::error::printStack(Foam::Ostream&) at ??:? #1 Foam::sigFpe::sigHandler(int) at ??:? #2 ? in "/lib/x86_64-linux-gnu/libc.so.6" #3 Foam::heRhoThermo<Foam::rhoThermo, Foam::pureMixture<Foam::sutherlandTransport<Foam::species::thermo<Foam::hConstThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleInternalEnergy> > > >::calculate() at ??:? #4 Foam::heRhoThermo<Foam::rhoThermo, Foam::pureMixture<Foam::sutherlandTransport<Foam::species::thermo<Foam::hConstThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleInternalEnergy> > > >::correct() at ??:? #5 ? at ??:? #6 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" #7 ? at ??:? Floating point exception (core dumped) |
January 25, 2018, 11:02 |
#14 |
Tobias Holzmann
Rep Power: 51 |
You know that the totalPressure just reduces the pressure (which is given p0) at the face according to the velocity (1/2 rho U^2). Using it should be coupled with the appropriate U boundaries.
I use totalPressure if I have a pressure based flow. But the appropriate U BC have to be set. Otherwise you will get an infinite acceleration.
January 25, 2018, 11:32 |
#15 | |
Deep
Rep Power: 8 |
This is the combination I used now: p Code:
inletExt { type totalPressure;//zeroGradient; p0 uniform 100.0e5; } inletPorous { type totalPressure;//zeroGradient; // psi psi; // gamma 1.4; p0 uniform 20.0e5; // value uniform 20.0e5; } outletExt { type fixedValue; value $internalField; } outletPorous { type fixedValue; value $internalField; } } Code:
inletExt { type pressureInletOutletVelocity;//fixedValue;//flowRateInletVelocity; //massFlowRate constant 0.1; //value uniform (0 0 -7000);//(0 0 0); value uniform (0 0 0); } inletPorous { type pressureInletOutletVelocity;//fluxCorrectedVelocity;//flowRateInletVelocity; value uniform (0 0 0); //phi phi; //rho rho; //massFlowRate constant 0.1; //value uniform (0 0 0); } outletExt { type inletOutlet; value uniform (0 0 0); inletValue uniform (0 0 0); } outletPorous { type inletOutlet; value uniform (0 0 0); inletValue uniform (0 0 0); } |
January 25, 2018, 11:59 |
#16 |
Deep
Rep Power: 8 |
I guess it now has become same as this particular thread here:
Foam::error::PrintStack Somewhere the BCs are still wrong. I keep going back to those warnings: rho min and rho max. |
January 25, 2018, 12:12 |
#17 |
Tobias Holzmann
Rep Power: 51 |
So based in your Output you have a big mass conservation problem. However, it can be related to a lot of things such as mesh, numerical setup. You are using steady state so you should underrelax. Furthermore, your warnings are related to the old limiting. Limited p instead. It is more conservative. It is hard to give you suggestions with the lack of information you give us. A case is always the best. A draft of the problem etc...
January 29, 2018, 05:31 |
#18 | |
Deep
Rep Power: 8 |
Mesh is simple enough: two blocks and no walls involved. Two inlets, one from the top (external compressible flow) and the other from bottom (through porous block). |
January 31, 2018, 13:59 |
Update
#19 |
Deep
Rep Power: 8 |
Hi Tobi,
I've attached the latest case here for 5.x. This case will run just fine but the initial conditions I've put in here are not the ones I'm interested in. Specifically I want to simulate this case for much higher pressures (of the order of 25-30 bar). When I change the inlets and internalField to such high values, it gives me the same floating point error with print stack. If at all there's something that makes pressure or density zero, i should have happened with lower pressure as well. How is this case pressure dependent ? Any clues ? Error log with higher pressures Code:
Create time Create mesh for time = 0 SIMPLE: convergence criteria field p tolerance 0.001 field U tolerance 0.0001 field e tolerance 0.001 field "(k|epsilon|omega)" tolerance 0.001 Reading thermophysical properties Selecting thermodynamics package { type heRhoThermo; mixture pureMixture; transport sutherland; thermo hConst; equationOfState perfectGas; specie specie; energy sensibleInternalEnergy; } Reading field U Reading/calculating face flux field phi --> FOAM Warning : From function Foam::pressureControl::pressureControl(const volScalarField&, const volScalarField&, const Foam::dictionary&, bool) in file cfdTools/general/pressureControl/pressureControl.C at line 125 Reading "/home/ywb17176/OpenFOAM/zProjects/x/system/fvSolution.SIMPLE" from line 52 to line 64 'rhoMax' specified rather than 'pMax' or 'pMaxFactor' This is supported for backward-compatibility but 'pMax' or 'pMaxFactor' are more reliable. --> FOAM Warning : From function Foam::pressureControl::pressureControl(const volScalarField&, const volScalarField&, const Foam::dictionary&, bool) in file cfdTools/general/pressureControl/pressureControl.C at line 182 Reading "/home/ywb17176/OpenFOAM/zProjects/x/system/fvSolution.SIMPLE" from line 52 to line 64 'rhoMin' specified rather than 'pMin' or 'pMinFactor' This is supported for backward-compatibility but'pMin' or 'pMinFactor' are more reliable. pressureControl pMax 2.65e+06 pMin 143849 Creating turbulence model Selecting turbulence model type RAS Selecting RAS turbulence model kEpsilon RAS { RASModel kEpsilon; turbulence on; printCoeffs on; Cmu 0.09; C1 1.44; C2 1.92; C3 0; sigmak 1; sigmaEps 1.3; } No MRF models present Creating finite volume options from "system/fvOptions" Selecting finite volume options model type fixedTemperatureConstraint Source: source1 - selecting cells using cellZone porouszone - selected 125000 cell(s) with volume 0.0001 Creating porosity model list from porosityProperties Porosity region porosity1: selecting model: DarcyForchheimer creating porous zone: porouszone Using pressure implicit porosity Starting time loop Time = 1 smoothSolver: Solving for e, Initial residual = 7.55303e-05, Final residual = 2.59832e-09, No Iterations 1 GAMG: Solving for p, Initial residual = 1, Final residual = 0.0246482, No Iterations 5 time step continuity errors : sum local = 1494.35, global = -444.3, cumulative = -444.3 pressureControl: p max 3.60081e+06 smoothSolver: Solving for epsilon, Initial residual = 1, Final residual = 0.0969739, No Iterations 20 smoothSolver: Solving for k, Initial residual = 1, Final residual = 0.0935749, No Iterations 20 ExecutionTime = 4.45 s ClockTime = 5 s Time = 2 smoothSolver: Solving for e, Initial residual = 8.75312e-05, Final residual = 4.64666e-06, No Iterations 1 GAMG: Solving for p, Initial residual = 0.991606, Final residual = 0.0242761, No Iterations 5 time step continuity errors : sum local = 5527.22, global = 1823.98, cumulative = 1379.68 pressureControl: p max 2.69438e+06 pressureControl: p min -1.34867e+06 smoothSolver: Solving for epsilon, Initial residual = 0.993871, Final residual = 0.0742512, No Iterations 2 smoothSolver: Solving for k, Initial residual = 0.0490147, Final residual = 0.00449648, No Iterations 4 ExecutionTime = 7.01 s ClockTime = 7 s Time = 3 smoothSolver: Solving for e, Initial residual = 0.00294211, Final residual = 0.0002079, No Iterations 1 GAMG: Solving for p, Initial residual = 0.662128, Final residual = 0.0289645, No Iterations 5 time step continuity errors : sum local = 3844.73, global = -1055.99, cumulative = 323.685 pressureControl: p max 3.87254e+06 pressureControl: p min -1.33612e+06 smoothSolver: Solving for epsilon, Initial residual = 0.746239, Final residual = 0.0591527, No Iterations 12 smoothSolver: Solving for k, Initial residual = 0.536278, Final residual = 0.0467291, No Iterations 12 ExecutionTime = 9.75 s ClockTime = 10 s Time = 4 smoothSolver: Solving for e, Initial residual = 0.00403889, Final residual = 0.00026221, No Iterations 2 GAMG: Solving for p, Initial residual = 0.791904, Final residual = 0.0314796, No Iterations 6 time step continuity errors : sum local = 2510.16, global = 430.837, cumulative = 754.522 pressureControl: p max 1.76649e+07 pressureControl: p min -5.41441e+06 smoothSolver: Solving for epsilon, Initial residual = 0.265591, Final residual = 0.0232256, No Iterations 10 smoothSolver: Solving for k, Initial residual = 0.227245, Final residual = 0.0182015, No Iterations 10 ExecutionTime = 12.51 s ClockTime = 13 s Time = 5 smoothSolver: Solving for e, Initial residual = 0.00757164, Final residual = 0.000557392, No Iterations 2 #0 Foam::error::printStack(Foam::Ostream&) at ??:? #1 Foam::sigFpe::sigHandler(int) at ??:? #2 ? in "/lib/x86_64-linux-gnu/libc.so.6" #3 Foam::heRhoThermo<Foam::rhoThermo, Foam::pureMixture<Foam::sutherlandTransport<Foam::species::thermo<Foam::hConstThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleInternalEnergy> > > >::calculate() at ??:? #4 Foam::heRhoThermo<Foam::rhoThermo, Foam::pureMixture<Foam::sutherlandTransport<Foam::species::thermo<Foam::hConstThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleInternalEnergy> > > >::correct() at ??:? #5 ? at ??:? #6 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" #7 ? at ??:? Floating point exception (core dumped) Last edited by deepbandivadekar; January 31, 2018 at 14:01. Reason: Added error log |
February 2, 2018, 07:59 |
#20 |
Tobias Holzmann
Rep Power: 51 |
Can you give us some description / draft about what your case should demonstrate? I am a bit doubtful about the physics behind. No wall, nothing?
printstack, rhoporoussimplefoam, thermophysicalproperties |
ANSYS Licensing Problem, Processes Running but Showing as Not Running | penguinman | ANSYS | 3 | September 27, 2016 13:30 |
Something weird encountered when running OpenFOAM in parallel on multiple nodes | xpqiu | OpenFOAM Running, Solving & CFD | 2 | May 2, 2013 04:59 |
Statically Compiling OpenFOAM Issues | herzfeldd | OpenFOAM Installation | 21 | January 6, 2009 09:38 |
Kubuntu uses dash breaks All scripts in tutorials | platopus | OpenFOAM Bugs | 8 | April 15, 2008 07:52 |
