[Sponsors] | |||||
simpleFoam diverges when MRF rotation is flipped |
#1 | |
James Gross
Rep Power: 10 ![]() |
Hi OFers,
I am doing a 2D simulation for a centrifugal pump. I am using MRF properties to perform a frozen rotor simulation. If I attempt to perform a simulation with rotation around the positive z axis, the simulation crashes and I receive a floating point exception. The solution at the time before it crashes is as follows: Quote:
J |
#2 | ||||||
James Gross
As a follow on from the previous comment, I am using k-omega SST simulation with cyclic AMI between a rotating and non-rotating region. I am aware the cyclic AMI is not necessary for MRF simulation, however I would like to be able to have non-conformal meshes between the rotating and non-rotating regions, particularly for when I begin to perform transient analysis.
The vast majority of the divSchemes give diverging results, with the lone exceptions being: Quote:
Looking at the log.simpleFoam, I notice that the bounding omega and bounding k values are larger than I would expect. At the latest time, I get: Quote:
J |
James Gross
Solved the problem by using more stable schemes and a different turbulence model. Also I think there were some issues with BCs.
Rep Power: 9 ![]() |
I am facing same issue while simulating mixing tank using MRF approach. Solution get diverged after some iterations. Can you please let me know how you solved. Or post your scheme files? |
| Thread Tools | Search this Thread |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| simpleFoam + MRF properties: FATAL ERROR: not implemented | student666 | OpenFOAM Running, Solving & CFD | 3 | April 11, 2021 04:11 |
| SRFSimpleFoam vs SimpleFoam (MRF) | oscar_urri | OpenFOAM Running, Solving & CFD | 9 | November 13, 2018 18:18 |
| Simulation of Radial Fan with simpleFoam MRF | nash | OpenFOAM Running, Solving & CFD | 2 | November 5, 2015 11:12 |
| Same SimpleFOAM Case converges with openFOAM 2.1 but diverges with openFOAM 2.0.1 | alsdia | OpenFOAM Running, Solving & CFD | 3 | October 22, 2012 12:25 |
| MRF rotation in unstady simulation | Clementhuon | Siemens | 0 | May 25, 2012 03:45 |
