Problem with the continuity error
Old   February 20, 2018, 13:16
Default Problem with the continuity error
ycui is on a distinguished road
I run simulations with two different flow rates, one has the continuity error as following:
[0] --> FOAM FATAL ERROR:
[0] Continuity error cannot be removed by adjusting the outflow.
Please check the velocity boundary conditions and/or run potentialFoam to initialise the outflow.
Total flux : 0.00019934231
Specified mass inflow : 0.00050030965
Specified mass outflow : 0.00050030965
Adjustable mass outflow : 0
My mass inflow and outflow are identical, why I recieved this error
Another simulation with a different flow rate runs smooth, all settings are the same.
ycui is offline   Reply With Quote
Old   February 21, 2018, 09:15
I solve the problem by freeing one outlet, i.e. set one velocity outlet as zeroGradient and the corresponding outlet pressure is changed into the fixedValue.
The idea is to adjust the volume flow rate by OpenFoam itself, in order to avoid the tolerance of numerical error.
[OpenFOAM.org] compile error in dynamicMesh and thermophysicalModels libraries NickG OpenFOAM Installation 3 December 30, 2019 01:21
DPM udf error haghshenasfard FLUENT 0 April 13, 2016 07:35
[OpenFOAM] Native ParaView Reader Bugs tj22 ParaView 270 January 4, 2016 12:39
POSDAT problem piotka STAR-CD 4 June 12, 2009 09:43
user subroutine error CFDUSER CFX 2 December 9, 2006 07:31
