February 25, 2018, 06:22 |
MRF embedded in another one
Marco Nicotra
Dear all,
I was wondering wheater it is possible to simulate in OpenFoam (steady simulation, no moving meshes) the motion of a rotating component (eg wheel with its spokes) , when its rotational axis (wheel axle) is itself rotating with respect to a fixed frame (eg roll motion around the wheel-ground contact patch). I found out that this is possible in Ansys Fluent using the "embedded reference frame" feature, which enables a moving reference frame to be referred to another fluid domain which itself is in motion. Anyone as suggestions? Thanks in advance MN |
moving reference frames, mrf simplefoam, mrf., simple foam, wheels |
MRF and topoSet problem- Rotating volume doesn't rotate | andreas0209@hotmail.com | OpenFOAM | 1 | April 4, 2021 13:35 |
[Commercial meshers] converting Fluent mesh to openfoam standard mesh | deepesh | OpenFOAM Meshing & Mesh Conversion | 31 | March 29, 2017 05:59 |
Possibly serious MRF implementation issue | Ali Blues | OpenFOAM Bugs | 1 | December 16, 2015 06:04 |
MRF setup | andreas0209@hotmail.com | OpenFOAM Pre-Processing | 1 | August 6, 2015 09:36 |
Should an empty MRF zone really induce this much cross-flow? | sylvester | OpenFOAM | 5 | November 18, 2010 03:48 |
