Write function in Laplacian Foam
Hi
I am new to the OpenFoam. I looked into laplacian Foam and solved the heat conduction through Flange. I also looked the solver directory of laplacian Foam. I want to understand how write.h function called. write.h calculates the gradient of temperature. I did not find any line related to this in code. Would you please shed light on it? Thank you in advance Mvee |
any response is welcomed!
The version I checked, there is a statement Code:
#include "write.H" Cheers, Antimony |
I was looking for the same but searching few initial lines of laplacianFoam.c file. It is actually mentioned in between the code.
Anyway, Thank you Mvee |
