naca12 laminar pimpleFoam
Hello, i'm new openfoam and try solve flow for naca12 with pimpleFoam in piso mode. airfoil in midle channel i use foamextend4. pimpleFoam always crash on second time step even if time step very smal. i dont know what problem is. anyone help? this is output
pimpleFoam
| \\ / F ield | foam-extend: Open Source CFD |
| \\ / O peration | Version: 4.0 |
| \\ / A nd | Web: http://www.foam-extend.org |
| \\/ M anipulation | For copyright notice see file Copyright |
Build : 4.0-10298020aac7
Exec : pimpleFoam
Date : Mar 16 2018
Time : 19:57:17
Host : carrera
PID : 20863
CtrlDict : "/home/uniciti/foam/uniciti-4.0/test/testCase-NACA0012/system/controlDict"
Case : /home/uniciti/foam/uniciti-4.0/test/testCase-NACA0012
nProcs : 1
SigFpe : Enabling floating point exception trapping (FOAM_SIGFPE).
Create time
Create mesh for time = 0
From function void polyMesh::initMesh()
in file meshes/polyMesh/polyMeshInitMesh.C at line 81
Truncating neighbour list at 87789 for backward compatibility
PIMPLE: Operating solver in PISO mode
Reading field p
Reading field U
Selecting incompressible transport model Newtonian
Selecting turbulence model type RASModel
Selecting RAS turbulence model laminar
Reading field aU if present
Starting time loop
Courant Number mean: 0.0274887 max: 0.507163 velocity magnitude: 0.5
Creating minMaxField for field U
Creating minMaxField for field p
Time = 0.001
PIMPLE: iteration 1
BiCGStab: Solving for Ux, Initial residual = 0.999999, Final residual = 1.66924e-10, No Iterations 2
BiCGStab: Solving for Uy, Initial residual = 1, Final residual = 1.40851e-10, No Iterations 2
GAMG: Solving for p, Initial residual = 1, Final residual = 7.57375e-07, No Iterations 31
time step continuity errors : sum local = 2.22698e-12, global = -8.61863e-21, cumulative = -8.61863e-21
ExecutionTime = 0.59 s ClockTime = 0 s
Courant Number mean: 0.0281978 max: 0.791337 velocity magnitude: 1.0436
Field U magnitude min = 0 max = 0.742286
Field p min = -2.04446 max = 3.70447
Time = 0.002
PIMPLE: iteration 1
BiCGStab: Solving for Ux, Initial residual = 0.028756, Final residual = 4.02589e-07, No Iterations 1
BiCGStab: Solving for Uy, Initial residual = 0.0292767, Final residual = 3.73316e-07, No Iterations 1
Floating point exception
pressure boundary condition
| \\ / O peration | Version: 1.5-dev |
| \\ / A nd | Revision: 1326 |
| \\/ M anipulation | Web: http://www.OpenFOAM.org |
FoamFile
version 2.0;
format ascii;
class volScalarField;
location "0";
object p;
dimensions [0 2 -2 0 0 0 0];
internalField uniform 0;
boundaryField
sides
type empty;
airfoil
type zeroGradient;
top
type zeroGradient;
bottom
type zeroGradient;
inlet
type zeroGradient;
outlet
type fixedValue;
value uniform 0;
velcocity boundary condition
| \\/ M anipulation | |
FoamFile
version 2.0;
format ascii;
class volVectorField;
location "0";
object U;
dimensions [ 0 1 -1 0 0 0 0 ];
internalField uniform ( 0.5 0 0 );
boundaryField
sides
type empty;
airfoil
type fixedValue;
value uniform ( 0 0 0 );
top
type fixedValue;
bottom
type fixedValue;
inlet
type fixedValue;
value uniform ( 0.5 0 0 );
outlet
type inletOutlet;
inletValue uniform ( 0 0 0 );
