Mass inflow and outflow are not equal
Old   March 29, 2018, 03:17
Default Mass inflow and outflow are not equal
Teun Verstraaten
slugger is on a distinguished road
Hello everybody. I am simulating air flow through an air bearing, where there is an inlet where the pressure is set to 5.5bar and an outlet where the pressure is set to 1.0bar. I have these boundary patches
bottomWall {
type wall;
topWall {
type wall;
outlet {
type outlet;
inlet {
type inlet;
wall {
type wall;
symmetry {
type wall;
where I surpressed the nFaces and startFace for brevity. The whole air bearing has some 4-fold symmetry, so I am simulating just one part. Where the parts should meet I put a boundary called symmetry where everything gets a zeroGradient BC.
Now, I want to see how much load the airbearing can support so I add the following to my controlDict
functions {
#includeFunc patchIntegrate(name=topWall,p)
#includeFunc patchIntegrate(name=outlet,phi)
#includeFunc patchIntegrate(name=inlet,phi)
#includeFunc patchIntegrate(name=bottomWall,phi)
#includeFunc patchIntegrate(name=topWall,phi)
#includeFunc patchIntegrate(name=wall,phi)
#includeFunc patchIntegrate(name=symmetry,phi)
I keep track of the mass flow through each face as a check to make sure nothing is off, but sure enough, the numbers do not match. The inflow through the inlet is about twice as high as the outflow from the outlet. Also, there is a small mass flow through the symmetry boundary which should not happen. I believe that the problem lies somewhere with my boundary conditions. I add here the p and U boundary conditions that I used, and as an attachment I have the entire simulation folder without the mesh (was too big). If anyone can see what is going wrong I would be very thankful!
pressure:
inlet {
type fixedValue;
value uniform 5.5E+5;
outlet {
type fixedValue;
value uniform 1.0E+5;
bottomWall {
type zeroGradient;
topWall {
type zeroGradient;
wall {
type zeroGradient;
symmetry {
type zeroGradient;
Velocity:
inlet
type zeroGradient;
outlet {
type zeroGradient;
bottomWall {
type noSlip;
topWall {
type noSlip;
wall {
type noSlip;
symmetry {
type zeroGradient;
slugger is offline   Reply With Quote
phi, rhosimplefoam
Mass Imbalance (mass inflow & outflow is not equal) Zahoor CFX 6 July 22, 2016 00:46
potentialFoam doesnt start?! Sway OpenFOAM Running, Solving & CFD 0 July 2, 2015 07:48
DSMC errors at inflow and outflow boundary wenjie OpenFOAM 5 February 20, 2013 23:27
Correct location for inflow and outflow boundaries Varun CFX 1 May 23, 2008 03:43
mass flux correction at outflow boundaries Subhra Datta Main CFD Forum 2 November 24, 2003 13:11
