Correct foamfile header for input file with mixed quantities (any version of OF)
I have a case that takes in certain input values from a file named "input" in the 0 folder. The input file has varied quantities (of various dimensions; see code below). I do not prefer to create separate input files e.g. classified by vectors/scalers. This single input file then is included in each of the inititalisation files (U, T, p...). For some reason the case ran successfully by commenting out the foamfile header in OF 5.x. However, for a the lack of availability of the OF 5.x on the cluster I have to run it with lower version: 2.4.0 And this is giving me an error: Code:
The error persists even after I uncomment the foamfile header in the input file, and with different keywords against class and object. I didn't find any resource to correct that. Does anyone know, what should be the correct foamfile header for this input file? How does it change with the different versions of OF (I'd like to know the correct header for OF 5.x as well) Code:
FoamFile |
Anyone at all ?
Bumping this up again.. just in case
How does your p dictionary look like? I'd like to see, how do you call these parameters in the intended dictionary.
I would do it like the turorial motorBike in tutorials\incompressible\pisoFoam\LES\motorBike. |
