Lorenzo Vergari
Rep Power: 9 ![]() |
Hello everybody,
I am simulating a cavity with a hole inside and with a fixedGradient for T on this hole surface (Laminar Flow). I made the mesh on gmsh, converted it to foam and then used buoyantBoussinesqPimpleFoam for the simulation. However, after a bit the simulation ends with an error i have never seen in my short OF experience. I attach the log file, if you could give it a glance it would be enormously useful! Thank you a lot! |
#2 | |
Hosein
Rep Power: 15 ![]() |
I just took a look at your logFile. As you can see your GAMGSolver is complaining with a floating point exception. But in fact the residuals of your pressure equation is not that high. However, you can take a look at the lines starting with smoothSolver. There you will clearly see that your residuals are on the order of e+158. long story made short: your setup is not correct. |
Lorenzo Vergari
hi einstein_zee, thanks for your reply.
I noticed the huge residuals and i am trying to figure out in what the setup is incorrect, even though i am having some difficulties in finding out what's wrong |
Display Modes | |
Building OpenFOAM1.7.0 from source | ata | OpenFOAM Installation | 46 | March 6, 2022 13:21 |
pimpleDyMFoam computation randomly stops | babapeti | OpenFOAM Running, Solving & CFD | 5 | January 24, 2018 05:28 |
How to write k and epsilon before the abnormal end | xiuying | OpenFOAM Running, Solving & CFD | 8 | August 27, 2013 15:33 |
IcoFoam parallel woes | msrinath80 | OpenFOAM Running, Solving & CFD | 9 | July 22, 2007 02:58 |
Could anybody help me see this error and give help | liugx212 | OpenFOAM Running, Solving & CFD | 3 | January 4, 2006 18:07 |
