cylinder
Like Tree1Likes
  • 1 Post By LuckyTran
Old   May 12, 2018, 06:51
Default cylinder
naufal
mnaufalazwar is on a distinguished road
Dear All, I am facing problem while going through the cylinder tutorials. i am new user of OpenFoam. in cylinder case when i put Allrun command to run i got this :
Restore 0/ from 0.orig/
Running blockMesh on /home/mnaufalazwar/OpenFOAM/mnaufalazwar-v1712/run/cylinder
Running potentialFoam on /home/mnaufalazwar/OpenFOAM/mnaufalazwar-v1712/run/cylinder
Running postProcess on /home/mnaufalazwar/OpenFOAM/mnaufalazwar-v1712/run/cylinder
and then when i try to open it in paraview by type parafoam i got this problem :
ERROR: ParaView reader module library (PVFoamReader) does not exist
Please build the reader module before continuing:
cd $WM_PROJECT_DIR/applications/utilities/postProcessing/graphics/PVReaders
./Allwclean
./Allwmake
Using the native VTK/OpenFOAM reader instead
Created temporary 'cylinder.foam'
ERROR: In /build/paraview-arsa8T/paraview-5.0.1+dfsg1/VTK/IO/Geometry/vtkOpenFOAMReader.cxx, line 8500
vtkPOpenFOAMReader (0x404cd00): Can't open /home/mnaufalazwar/OpenFOAM/mnaufalazwar-v1712/run/cylinder/constant/
ERROR: In /build/paraview-arsa8T/paraview-5.0.1+dfsg1/VTK/Common/ExecutionModel/vtkExecutive.cxx, line 784
vtkPVCompositeDataPipeline (0x3fab710): Algorithm vtkPOpenFOAMReader(0x404cd00) returned failure for request: vtkInformation (0x404fa40)
Debug: Off
Modified Time: 160366
Reference Count: 1
Registered Events: (none)
Request: REQUEST_INFORMATION
ALGORITHM_AFTER_FORWARD: 1
FORWARD_DIRECTION: 0
and the paraview was opened but nothing shows up. Please help me to understand this problem. thaks
mnaufalazwar is offline   Reply With Quote
Old   May 13, 2018, 02:45
Lucky
Error is here:
Check if the constant/polyMesh/ exists and it has files in it like: boundary,cellzones,faces,neighbour,owner, and points
Even if you fail at running potentialFoam or the postProcess utility, you can at least open a mesh in paraView/paraFoam as long as you have a valid mesh.
mnaufalazwar likes this.
Old   May 14, 2018, 00:23
naufal
thank for your respons, oke i have no such the constant directory, how do i fixed that?
Old   May 14, 2018, 20:49
Lucky
I don't know which tutorial you are running but it failed at blockMesh or even earlier.
Find your blockMeshDict. Usually it sits in constant/polyMesh but sometimes also in system. If you can't find this file, you're missing files. Happy hunting.
Flow past a 2D cylinder - High Re (1E+05) - Cd too high Pervispasco OpenFOAM Running, Solving & CFD 4 March 14, 2022 02:19
Drag force coefficient too high for a flow past a cylinder using komega sst Scabbard OpenFOAM Running, Solving & CFD 37 March 21, 2016 16:16
Forces Acting on a Rotating Cylinder (Moving Mesh) dreamchaser CFX 5 April 25, 2015 06:01
Incorrect Drag and Drag Coefficient for flow over a cylinder ozzythewise Main CFD Forum 8 June 13, 2012 06:24
[blockMesh] Specifying boundary faces failes in blockMesh blaise OpenFOAM Meshing & Mesh Conversion 0 May 10, 2010 03:56
