Negative temperature with twoPhaseEulerFoam
Old   May 13, 2018, 09:20
Default Negative temperature with twoPhaseEulerFoam
krishnan
tankerp is on a distinguished road
Hi !!!
I am currently using the twoPhaseEulerFoam solver to study spray formation with air and water.
I initially simulated a single phase flow with rhoPimpleFoam(since the air flow is compressible). The simulation converged, so I moved onto the two phase simulations.
With twoPhaseEulerFoam, my simulations continuously result in negative temperatures for air. Does anyone have any suggestions for this problem? I have attached the error log below:
fieldAverage fieldAverage1 write:
Calculating averages
Courant Number mean: 9.677663e-05 max: 0.07496172
Max Ur Courant Number = 0.5125739
deltaT = 4.898478e-09
Time = 0.0006120702
PIMPLE: iteration 1
MULES: Solving for alpha.air
alpha.air volume fraction = 0.9950781 Min(alpha.air) = 0 Max(alpha.air) = 1
Constructing momentum equations
smoothSolver: Solving for e.air, Initial residual = 1.196049e-05, Final residual = 5.437223e-10, No Iterations 1
smoothSolver: Solving for e.water, Initial residual = 1.687357e-06, Final residual = 1.802551e-12, No Iterations 1
min T.air 4.285799
min T.water 227.2014
GAMG: Solving for p_rgh, Initial residual = 3.477521e-05, Final residual = 4.661494e-16, No Iterations 1
GAMG: Solving for p_rgh, Initial residual = 4.661153e-16, Final residual = 4.661153e-16, No Iterations 0
GAMG: Solving for p_rgh, Initial residual = 2.884329e-05, Final residual = 4.12967e-16, No Iterations 1
GAMG: Solving for p_rgh, Initial residual = 4.130639e-16, Final residual = 4.130639e-16, No Iterations 0
PIMPLE: iteration 2
smoothSolver: Solving for e.air, Initial residual = 3.511325e-06, Final residual = 2.756874e-10, No Iterations 1
smoothSolver: Solving for e.water, Initial residual = 2.847783e-05, Final residual = 1.862502e-11, No Iterations 1
min T.air 0.1135057
min T.water 224.8915
GAMG: Solving for p_rgh, Initial residual = 2.938289e-05, Final residual = 4.642091e-16, No Iterations 1
GAMG: Solving for p_rgh, Initial residual = 4.643053e-16, Final residual = 4.643053e-16, No Iterations 0
GAMG: Solving for p_rgh, Initial residual = 2.892439e-05, Final residual = 4.064227e-16, No Iterations 1
GAMG: Solving for p_rgh, Initial residual = 4.065217e-16, Final residual = 4.065217e-16, No Iterations 0
smoothSolver: Solving for epsilonm, Initial residual = 0.00254583, Final residual = 2.93189e-08, No Iterations 1
smoothSolver: Solving for km, Initial residual = 0.0004375, Final residual = 6.476975e-09, No Iterations 1
ExecutionTime = 1122.68 s
Courant Number mean: 9.440734e-05 max: 0.07565087
Max Ur Courant Number = 0.5126871
deltaT = 4.777259e-09
Time = 0.000612075
PIMPLE: iteration 1
smoothSolver: Solving for e.air, Initial residual = 2.587203e-05, Final residual = 5.203098e-08, No Iterations 1
smoothSolver: Solving for e.water, Initial residual = 1.830379e-06, Final residual = 1.922872e-12, No Iterations 1
min T.air -0.5202558
min T.water 224.9178
GAMG: Solving for p_rgh, Initial residual = 5.205457e-05, Final residual = 4.613364e-16, No Iterations 1
GAMG: Solving for p_rgh, Initial residual = 4.608789e-16, Final residual = 4.608789e-16, No Iterations 0
GAMG: Solving for p_rgh, Initial residual = 2.082419e-05, Final residual = 4.038371e-16, No Iterations 1
GAMG: Solving for p_rgh, Initial residual = 4.039299e-16, Final residual = 4.039299e-16, No Iterations 0
PIMPLE: iteration 2
[7] #0 Foam::error:rintStack(Foam::Ostream&) at ??:?
[7] #1 Foam::sigFpe::sigHandler(int) at ??:?
[7] #2 ? in "/lib/x86_64-linux-gnu/libc.so.6"
[7] #3 ? in "/lib/x86_64-linux-gnu/libm.so.6"
[7] #4 pow in "/lib/x86_64-linux-gnu/libm.so.6"
[7] #5 Foam:ow(Foam::Field<double>&, Foam::UList<double> const&, double const&) at ??:?
[7] #6 Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam:ow<Foam::fvPatchField, Foam::volMesh>(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::dimensioned<double> const&) at ??:?
[7] #7 Foam::dragModels::SchillerNaumann::CdRe() const at ??:?
[7] #8 Foam::dragModel::Ki() const at ??:?
[7] #9 Foam::dragModel::K() const at ??:?
[7] #10 Foam::BlendedInterfacialModel<Foam::dragModel>::K( ) const at ??:?
[7] #11 Foam::twoPhaseSystem::Kd() const at ??:?
[7] #12 ? at ??:?
[7] #13 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
[7] #14 ? at ??:?
[carnage:23562] *** Process received signal ***
[carnage:23562] Signal: Floating point exception (8)
[carnage:23562] Signal code: (-6)
[carnage:23562] Failing at address: 0x3e900005c0a
[carnage:23562] [ 0] /lib/x86_64-linux-gnu/libc.so.6(+0x354b0)[0x7f917d3bc4b0]
[carnage:23562] [ 1] /lib/x86_64-linux-gnu/libc.so.6(gsignal+0x38)[0x7f917d3bc428]
[carnage:23562] [ 2] /lib/x86_64-linux-gnu/libc.so.6(+0x354b0)[0x7f917d3bc4b0]
[carnage:23562] [ 3] /lib/x86_64-linux-gnu/libm.so.6(+0x12601)[0x7f917d979601]
[carnage:23562] [ 4] /lib/x86_64-linux-gnu/libm.so.6(pow+0x14)[0x7f917d988e54]
[carnage:23562] [ 5] /home/rhoheth/OpenFOAM/OpenFOAM-4.0/platforms/linux64GccDPInt64Opt/lib/libOpenFOAM.so(_ZN4Foam3powERNS_5FieldIdEERKNS_5UL istIdEERKd+0x38)[0x7f917e7f2418]
[carnage:23562] [ 6] /home/rhoheth/OpenFOAM/OpenFOAM-4.0/platforms/linux64GccDPInt64Opt/lib/libcompressibleTurbulenceModels.so(_ZN4Foam3powINS _12fvPatchFieldENS_7volMeshEEENS_3tmpINS_14Geometr icFieldIdT_T0_EEEERKS7_RKNS_11dimensionedIdEE+0x23 7)[0x7f9182a582b7]
[carnage:23562] [ 7] /home/rhoheth/OpenFOAM/OpenFOAM-4.0/platforms/linux64GccDPInt64Opt/lib/libcompressibleEulerianInterfacialModels.so(_ZNK4F oam10dragModels15SchillerNaumann4CdReEv+0x1e0)[0x7f9181b5d1c0]
[carnage:23562] [ 8] /home/rhoheth/OpenFOAM/OpenFOAM-4.0/platforms/linux64GccDPInt64Opt/lib/libcompressibleEulerianInterfacialModels.so(_ZNK4F oam9dragModel2KiEv+0x145)[0x7f9181b21455]
[carnage:23562] [ 9] /home/rhoheth/OpenFOAM/OpenFOAM-4.0/platforms/linux64GccDPInt64Opt/lib/libcompressibleEulerianInterfacialModels.so(_ZNK4F oam9dragModel1KEv+0x2e)[0x7f9181b2123e]
[carnage:23562] [10] /home/rhoheth/OpenFOAM/OpenFOAM-4.0/platforms/linux64GccDPInt64Opt/lib/libcompressibleTwoPhaseSystem.so(_ZNK4Foam23Blende dInterfacialModelINS_9dragModelEE1KEv+0x4be)[0x7f9181f69ace]
[carnage:23562] [11] /home/rhoheth/OpenFOAM/OpenFOAM-4.0/platforms/linux64GccDPInt64Opt/lib/libcompressibleTwoPhaseSystem.so(_ZNK4Foam14twoPha seSystem2KdEv+0x32)[0x7f9181f45532]
[carnage:23562] [12] twoPhaseEulerFoam[0x43a9fb]
[carnage:23562] [13] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xf0)[0x7f917d3a7830]
[carnage:23562] [14] twoPhaseEulerFoam[0x44e3b9]
[carnage:23562] *** End of error message ***
mpirun noticed that process rank 7 with PID 23562 on node carnage exited on signal 8 (Floating point exception).
tankerp is offline   Reply With Quote
Old   May 13, 2018, 09:24
krishnan
I can provide more information if required!
Old   May 15, 2018, 23:43
Ed Barry
ed_bar is on a distinguished road
You've got a divide by zero in there somewhere. Have you copied across a tutorial case and changed mesh and BC/ICs for your conditions? If so, you will need to determine if the discretisation methods and solution controls are appropriate for your case. How many outer correctors do you have? How's your mesh (hint: checkMesh). If the non-orthogonality is above 0.5, then you will need to throw in some nNonOrthogonalCorrectors.
There are many things that could have gone wrong. Please reply with your case attached, or link to the case on github if possible.
ed_bar is offline   Reply With Quote
whats the cause of error? immortality OpenFOAM Running, Solving & CFD 13 March 24, 2021 07:15
Error Prevention: Negative Temperature Throws Fatal Error in Fluid Sim ben_ OpenFOAM Running, Solving & CFD 1 August 28, 2017 12:56
is internalField(U) equivalent to zeroGradient? immortality OpenFOAM Running, Solving & CFD 7 March 29, 2013 01:27
negative fluid temperature JeanPierre FLOW-3D 2 January 3, 2012 16:24
Negative temperature Julie Siemens 7 September 13, 2004 08:39
