Probing line data into a single file
I am probing line data in openfoam, and use the following code within the controlDict file. Code:
probeLineData Does anyone know a way to do this? or Can you suggest me any solution? Cheers, Cyln |
Hi!
Honestly I don't know if you can do that, maybe you can. But if you use "setFormat gnupot;", then you can plot the different time levels in the same figure easily. |
You can use singleGraph function. Include this line in your controlDict:
functions Code:
cp $FOAM_ETC/caseDicts/postProcessing/graphs/singleGraph system |
