turbulentInlet perturbations dies out
Old   June 1, 2018, 03:51
Default turbulentInlet perturbations dies out
Anonymous
backscatter is on a distinguished road
I was running an LES case (channel with a cubical obstacle in the middle) for generating turbulent velocity field for subsequent simulations. I used turbulentInlet b.c for velocity inlet to generate some random uncorrelated noise. But to my surprise, these random perturbations seem to die out too fast and flow appears to be laminar. I tried increasing the intensity of the random fluctuating component but to no avail, as the flow ultimately turns laminar with rapidly dissipating noise.
Could it be the dissipation from the mesh causing it?
Has anyone else encountered this issue before?
Any help is appreciated!
backscatter is offline   Reply With Quote
Old   June 1, 2018, 08:03
Tomas Denk
TomasDenk is on a distinguished road
Have you checked what is the Reynolds number for your flow? Could it be, that it is in fact laminar and the perturbations you introduce on the inlet are unphysical and therefore die out?
TomasDenk is offline   Reply With Quote
Old   June 1, 2018, 09:01
Santiago Lopez Castano
Santiago is on a distinguished road
Anyway uncorrelated noise set directly on the velocity will, depending on the discretization of div(Uu), be dissipated by numerical viscosity or mess up with the pressure solver residuals. Avoid using such bc for canonical studies.
Santiago is offline   Reply With Quote
Old   June 1, 2018, 10:42
Anonymous
This case has been tried out before by researchers. Re is around 6000(based on channel half height.
Old   June 1, 2018, 10:45
Anonymous
I was also thinking about this being the cause. I'll try changing the discretization scheme to see if that makes any difference...
Old   June 1, 2018, 11:51
You can do something better: just not to use it. Run a precursor simulation of a turbulent channel, with the same Re, until it reaches a statistically steady solution. Then extract vertical planes that would serve as inflow, using timeVaryingMappedFixedValue patch.
Another way is to construct a POD of a turbulent channel database to use as an inflow. This method, although approximate and relatively tricky, proves very flexible.
Old   September 21, 2018, 04:59
Ruiyan Chen
cryabroad is on a distinguished road
Seems like starting from v1606 openFOAM (the .com one) offers a B.C. of turbulentDFSEMInlet, have you tried it?
Related info can be found here: https://www.openfoam.com/releases/op...conditions.php
cryabroad is offline   Reply With Quote
Old   September 21, 2018, 23:35
Anonymous
Thanks Ruiyan for the info. I have checked it out in past while I was still searching answers for this post..
Old   September 22, 2018, 04:37
Arnout
The King is on a distinguished road
Same happened to my simulations. Use a sampling plane close to your outflow to set turbulence at the inlet. If it’s far enough away, you should not get periodic effects.
A
The King is offline   Reply With Quote
Old   October 14, 2018, 02:50
Ruiyan Chen
I have been having this type of problem for a while and here is what I have found after searching a lot.
First of all, the turbulentInlet B.C. is just some white noise, as being pointed out by other posts, the perturbations easily die out downstream due to numerical viscosity. Of course you can adopt the "recycling" approach, meaning get some data downstream and feed it at the inlet over and over again, but this is not very practical at least in my view.
Second, you can check out the inflowGenerator developed at Rostock, just search inflowGenerator or LEMOS. I've tested this B.C. (no fully) for a while, and it does give you correlated velocity at the inlet and some fluctuations downstream. I also experienced the problem of perturbations dying out quickly downstream but as I refined my mesh, this problem seems to go away (still doing the test so this may not be true).
Anyway, I think the above B.C. plus appropriate mesh and numerical schemes can definitely give you way better results. For my case, which is just flow inside a cylindrical pipe, I already tried mesh with around 170,000 cells (125 cells in the axial direction, this direction is very crucial!) and the perturbations downstream are quite obvious!
turbulentInlet (FvPatchField) mirz OpenFOAM Programming & Development 0 September 10, 2015 10:14
lift distribution's sensitivity to geometric perturbations JanH SU2 0 November 13, 2014 11:16
Perturbations in LES solvers leonardo.morita OpenFOAM Running, Solving & CFD 0 June 8, 2009 08:24
turbulentInlet + exp. non uniform reference field syoon OpenFOAM Running, Solving & CFD 4 March 31, 2009 11:18
Perturbations Dinesh godavarty Main CFD Forum 0 September 26, 2000 11:29
