rhoSimpleFoam converginv-diverging nozzle
Like Tree2Likes
  • 1 Post By sheaker
  • 1 Post By Hillie
Old   June 1, 2018, 08:08
Default rhoSimpleFoam converginv-diverging nozzle
Stevie_1200's Avatar
Steven Taggart
Stevie_1200 is on a distinguished road
I am fairly new to OpenFOAM but I have been working in CFD for a few year, at my company I have been tasked with implementing OpenFOAM as their CFD solution to get around license costs. We primarily work with gas pressure relief valves so its generally all highly compressible flows that I am dealing with. To get started I have been working with a converging-diverging nozzle from an old NASA study, I have set it up in a manner of different ways but struggling to get the expected behaviour for this type of problem.
I have it configured as a pressure driven flow with a pressure drop of 1.3BARg across the nozzle, I have tried many other configurations but this is the most recent. Generally the solution achieved with OpenFOAM results in either the inlet pressure spreading through the whole nozzle and just forming a uniform pressure field with no acceleration in the diverging outlet. Or also I have achieved a solution with some high pressure cells against the outlet boundary (see attached image). I have been working at this problem for some time but cannot find the issue with my setup.
I have used.
Inlet :-
Pressure - total pressure (230000)
Temperature - zeroGradient
Velocity - zeroGradient
Outlet :-
Pressure - total pressure (100000)
I have also tried prescribing velocity values at the outlet but that is when I result in a uniform pressure field throughout the nozzle.
Can anyone guide me on issues with the setup?
Thanks for your time.
Stevie_1200 is offline   Reply With Quote
Old   June 1, 2018, 08:20
sheaker's Avatar
Oskar
sheaker is on a distinguished road
Hello. As I remember I have successfully simulate tesla valve with pressure driven flow.
Here are pressure and velocity inlet files:
| \\      /  F ield         | OpenFOAM Extend Project: Open Source CFD        |
|  \\    /   O peration     | Version:  1.6-ext                               |
|   \\  /    A nd           | Web:      www.extend-project.de                 |
FoamFile
    version     2.0;
    format      ascii;
    class       volScalarField;
    object      p;
dimensions      [0 2 -2 0 0 0 0];
internalField   uniform 111325;
boundaryField
    inlet
        type            totalPressure;
        p0              uniform 111325;
//        type            timeVaryingTotalPressure;
//        p0              100040; // only used for restarts
//        outOfBounds     clamp;
//        fileName        "$FOAM_CASE/constant/p0vsTime";
        U               U;
        phi             phi;
        rho             none;
        psi             none;
        gamma           1;
        value           uniform 111325;
    outlet
        type            fixedValue;
        value           uniform 101325;
    wall
        type            zeroGradient;
    defaultFaces
    type        empty;
FoamFile
    version     2.0;
    format      ascii;
    class       volVectorField;
    object      U;
dimensions      [0 1 -1 0 0 0 0];
internalField   uniform (0 0 0);
boundaryField
    inlet
        type            pressureInletVelocity;
        value           uniform (0 0 0);
    outlet
        type            inletOutlet;
        inletValue      uniform (0 0 0);
    wall
        type            fixedValue;
    defaultFaces
    type        empty;
Have a nice day,
Sheaker
Stevie_1200 likes this.
sheaker is offline   Reply With Quote
Old   June 1, 2018, 09:09
Steven Taggart
Hi Sheaker,
I will give that configuration a try.
Thank you.
Steven
Old   June 6, 2018, 02:47
Hilbert
Hillie is on a distinguished road
Hi Stevie,
The conditions by shaker are looking quite good. I would just add that you do need a total temperature condition at the inlet as well.
Also with the current setup you might get supersonic flow in the throat, (not sure if you are expecting this). rhoSimpleFoam is not setup to deal with this, and so it will crash if the solution goes supersonic.
Hope it helps
Hillie is offline   Reply With Quote
Old   June 6, 2018, 04:14
Steven Taggart
Hi Hillie,
Thanks for your reply, I am actually looking for choking in the throat and supersonic flow downstream of that. I chose rhoSimpleFoam as it was the only steady-state compressible solver. I ended up giving up with that solver as I could not get a steady simulation. I moved to rhoCentralFoam and everything worked fine, I am going to look at rhoPimpleFoam for turbulent work.
Is it the correct decision to move to these solvers for supersonic flow, I am looking for a steady state simulation but these seem to be the only way I can obtain it.
Thanks for your help.
Steven.
Old   June 6, 2018, 04:29
Hilbert
Hi Stevie,
If you want to obtain supersonic flow sonicFoam and rhoCentralFoam are the only solver you can choose from. The others will just crash.
rhoCentralFoam can deal with turbulence modelling, and I have always gotten good results out of it. If you change the interpolation schemes in rhocentral from vanLeer to Gamma you get a lot better results.
Also both sonicFoam van rhoCentral are transient solvers. If you use local time stepping you can accelerate your solution quite a bit.
Cheers
Old   June 6, 2018, 04:36
Steven Taggart
Hi Hille,
That's excellent, thanks for your advice.
Steven
compressible flows, nozzle flow, rhosimplefoam
How to determine the distance between points on Converging diverging nozzle geometry Sorwar22 FLUENT 0 December 4, 2017 21:07
compressible, rhoSimpleFoam, multi-species, steady state, rocket nozzle David_C OpenFOAM Running, Solving & CFD 1 April 18, 2017 12:01
transsonic nozzle with rhoSimpleFoam Unseen OpenFOAM Running, Solving & CFD 7 April 16, 2014 04:38
Converging Diverging Nozzle in OpenFOAM danishdude OpenFOAM Running, Solving & CFD 1 September 15, 2012 01:12
compressible flow in a counterflow nozzle d.vamsidhar FLUENT 0 November 24, 2005 02:45
