December 15, 2017, 07:37 |
Realizable k-epsilon doenst work
Rep Power: 8 |
I tried to use the realizable kEpsilon model instead of the kEpsilon model. The simunlation does run with kEpsilon, but when i switch to the realizable kEpsilon my simulation stops at the calculation of k. I did not change anything for k. Does anyone know what might be the problem? |
December 15, 2017, 09:26 |
Rep Power: 8 |
Nvm it works.
June 14, 2018, 05:37 |
Hi Friendly!
Could you please tell me what did you do to fix the problem? I mean, I'm facing the same problem, to pass from standard kEpsilon to relizablekEpsilon, and the run stops when k is solved. Thank you! |
Creating a new field from terms of the turbulence model | HaZe | OpenFOAM Programming & Development | 15 | November 24, 2014 13:51 |
Do all CFD analysts have to do some hands-on work except PhDs? | e13drd | Main CFD Forum | 2 | March 17, 2014 14:56 |
Bounding k and epsilon & coldEngineFoam | sasanghomi | OpenFOAM | 1 | September 13, 2013 12:12 |
problem from k epsilon to k omega | NJG | OpenFOAM Running, Solving & CFD | 0 | April 15, 2013 08:24 |
ATTENTION! Reliability problems in CFX 5.7 | Joseph | CFX | 14 | April 20, 2010 15:45 |
