March 8, 2021, 13:56 |
Crash between two Info statements
Thomas
Rep Power: 7 |
Hi all,
I have been struggling with an error for a few days and I don't know what to check anymore. In my createFields.H, I have 2 lines: Code:
Info << "Correcting model " << nl; Info << "test1" << nl; Code:
Correcting model ... Thanks in advance for your answers. Last edited by Roxxor91; March 8, 2021 at 15:30. |
March 8, 2021, 14:56 |
Rep Power: 14 |
Umm, I am puzzled as well ... your first Info line prints "Correcting model", which is not the same as the line that you say it gets to ("Creating constitutive model") ... perhaps it is crashing elsewhere?
March 8, 2021, 15:30 |
#3 | |
Thomas
Rep Power: 7 |
I corrected in my post, and what I said remains valid though. |
March 8, 2021, 15:36 |
Rep Power: 14 |
Okay - that is strange then. It might be helpful to see what comes before after the two lines that you included. There is surely no memory problem with printing lines to Info, so I wonder whether the second line is buffered for output, but didn't get printed before the run stopped. Are you running this serial or parallel?
You could always try putting an exit(0) line after the second line & recompile, to force the code to stop and flush the buffer - that will tell you if it made it past the second line or not. Otherwise, there must be something else that is causing the problem. |
March 8, 2021, 16:22 |
#5 | |
Thomas
Rep Power: 7 |
I have changed some lines in the code, and now I am able to run the simulation a bit further. Although I cannot confirm at 100% there was no division by 0, if there actually was then the crash would not occur between two Info statements.. So a bit of an update: I am able to run the simulation up to a certain point. With my fine mesh and a CFL of 0.3, it crashes at Code:
Time Step =26 deltaT = 6.495373218822619e-05 s Time = 0.001688669040940589 s Simulation completed = 84.433% - Clock = 14s Post Processing ... L2errorLM = 0.03768430191941113 L2errorP_ = 0.0218538063768106 Time Step =27 deltaT = 6.49543441287486e-05 s Time = 0.001753623385069337 s Code:
Time Step =26 deltaT = 4.329966609208541e-05 s Time = 0.001125754647590129 s Simulation completed = 56.288% - Clock = 14s Post Processing ... L2errorLM = 0.02622370505848511 L2errorP_ = 0.007653927455782624 Time Step =27 deltaT = 4.32998451625767e-05 s Time = 0.001169054492752705 s Code:
Time Step =26 deltaT = 2.164901948667259e-05 s Time = 0.0005628702820208933 s Simulation completed = 28.144% - Clock = 13s Time Step =27 deltaT = 2.164904018477349e-05 s Time = 0.0005845193222056668 s The folllowing is the code snippet where it crashes, including the time loop: Code:
while (runTime.loop()) { if (timeStepping == "variable") { stretch = mech.stretch(); scalar minStretch = GREAT; forAll(stretch, n) { if (stretch[n] < minStretch) { minStretch = stretch[n]; } } deltaT = (cfl*h)/(model.Up()/minStretch); runTime.setDeltaT(deltaT); //Info << "minimum stretch: " << minStretch << nl; } t += deltaT; tstep++; Info << "\nTime Step =" << tstep << "\n deltaT = " << deltaT.value() << " s" << "\n Time = " << t.value() << " s" << endl; x.oldTime(); xw.oldTime(); You can notice that I crash always at the same iteration, how weird is this ? |
March 9, 2021, 16:35 |
Rep Power: 14 |
March 14, 2021, 10:25 |
Thomas
Rep Power: 7 |
March 14, 2021, 11:18 |
Rep Power: 14 |
... and it always crashes on iteration 27? Are you storing in memory data from each iteration? I am wondering whether one of your arrays is going out of bounds ... otherwise, difficult to comment further without seeing all the code.
If you have the patience, you could compile it with debugging, and run a debugger to see exactly what is happening. Not a quick task, but it might provide a way out ... again, good luck. |
[Gmsh] gmshToFoam generates patches with 0 faces and 0 points | Simurgh | OpenFOAM Meshing & Mesh Conversion | 4 | August 25, 2023 07:58 |
[Gmsh] 3D coil mesh: can't create the volume? | RomainBou | OpenFOAM Meshing & Mesh Conversion | 3 | July 18, 2016 05:09 |
[Gmsh] Cgns support for gmsh | robyTKD | OpenFOAM Meshing & Mesh Conversion | 1 | July 13, 2016 11:27 |
[Gmsh] Vertex numbering is dense | KateEisenhower | OpenFOAM Meshing & Mesh Conversion | 7 | August 3, 2015 10:49 |
OpenFOAM with Cygwin | kitchener | OpenFOAM Installation | 6 | April 24, 2006 23:09 |
