omdemircan |
July 4, 2018 08:41 |
rotatingWallFunction not working properly
1 Attachment(s)
Hi Foamers,
I am trying simulate a rotating cylinder at transonic speeds in 2D using rhoPimpleFoam of the OpenFOAM 5.0 code package. However, the simulation output is almost the same as a static cylinder. Below is my U file with the BC that I have used.
I have also attached a contour showing the instantaneous Ma number. Top one is static and the bottom one is with the rotating cylinder.
Am I missing something here?
| \\ / O peration | Version: 4.1 |
| \\ / A nd | Web: www.OpenFOAM.org |
| \\/ M anipulation | |
FoamFile
version 2.0;
format ascii;
class volVectorField;
location "0";
object U;
dimensions [0 1 -1 0 0 0 0];
internalField uniform (289.25 0 0);
boundaryField
inlet
type fixedValue;
value uniform (289.25 0 0);
outlet
type zeroGradient;
fixedWall
type noSlip;
movingWall
type rotatingWallVelocity;
origin (-0.009525 0.009017 0);
axis (0 0 1);
omega 104.72; // rad/s
slip
type symmetry;
empty
type empty;
