July 13, 2018, 08:14 |
Floating point exception (core dumped)
Vivek
Rep Power: 8 |
I am using interFoam solver for the simulation of 2D Spray mechanism.I am facing two different kind of errors. 1. Courant Number mean: 2.4426e-10 max: 0.696321 Interface Courant Number mean: 2.18474e-14 max: 0.000194981 deltaT = 7.78442e-111 Time = 1.69242e-05 PIMPLE: iteration 1 MULES: Solving for alpha.water Phase-1 volume fraction = 2.57694e-11 Min(alpha.water) = -0.554977 Max(alpha.water) = 1 MULES: Solving for alpha.water Phase-1 volume fraction = 2.57694e-11 Min(alpha.water) = -0.554891 Max(alpha.water) = 1 #0 Foam::error:rintStack(Foam::Ostream&) at ??:? #1 Foam::sigFpe::sigHandler(int) at ??:? #2 ? in "/lib64/libc.so.6" #3 double Foam::sumProd<double>(Foam::UList<double> const&, Foam::UList<double> const&) at ??:? #4 Foam::PCG::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const at ??:? #5 Foam::fvMatrix<double>::solveSegregated(Foam::dict ionary const&) at ??:? #6 Foam::fvMatrix<double>::solve(Foam::dictionary const&) at ??:? #7 ? at ??:? #8 __libc_start_main in "/lib64/libc.so.6" #9 ? at ??:? Floating point exception (core dumped) 2. FOAM Warning : From function virtual void Foam::wedgePolyPatch::calcGeometry(Foam::PstreamBu ffers&) in file meshes/polyMesh/polyPatches/constraint/wedge/wedgePolyPatch.C at line 70 Wedge patch 'frontAndBackPlanes_neg' is not planar. At local face at (-0.0999909 0.02875 -0.00125406) the normal (0 -0.0435786 -0.99905) differs from the average normal (-1.87367e-08 -0.0435779 -0.99905) by 4.02353e-13 Either correct the patch or split it into planar parts These are two errors i am facing .i tried with many different courant no ranging from 0.01 to 100. i dont know exactly where i am making mistakes. i also searched thread related to this problem. i am not able figure it out. Any suggestions ?? |
July 13, 2018, 08:41 |
#2 | |
Santiago Lopez Castano
Rep Power: 15 |
Floating Point Exception Error | nyox | FLUENT | 11 | November 30, 2018 12:31 |
Floating point exception (core dumped), running a new solver | Mahyar Javidi | OpenFOAM Running, Solving & CFD | 6 | April 7, 2018 12:43 |
simpleFoam: floating point exception | student666 | OpenFOAM Running, Solving & CFD | 9 | March 13, 2016 18:23 |
sonicFoam - Floating point eception (core dumped) | MSans | OpenFOAM Running, Solving & CFD | 12 | August 4, 2015 05:10 |
Floating point exception (core dumped) for GAMG solver | yuhou1989 | OpenFOAM Running, Solving & CFD | 2 | March 24, 2015 19:28 |
