What is the difference between "includefunc residuals" and the residuals in log-file?
I'm trying to run an inviscid, incompressible flow (Euler equations) around a wing with simpleFoam with nu set to zero. I'm trying to judge convergence and noticed that the final residuals in the log-file (by running simpleFoam > log) are in the order of e-09, whereas the residuals in the .dat file generated with "includefunc residuals" are in the order of e-02. What is the difference between the two? Why are they not the same? Here's the last log entry: Code:
Time = 3000 Code:
# Time p Ux Uy Uz Bruno |
It looks like the initial residuals are those pulled by the function, not the final ones.
Caelan |
Wow, well spotted, thanks! |
