luiscoliveira |
August 3, 2018 11:15 |
InterFoam convergence
4 Attachment(s)
Hi everyone!
I'm playing around with a case similar to the multiphase DTCHull, but with a Wigley hull. I'm using OF 5.X in my main machine and 2.3.X in another one. I'm using 2.3.X because of LTSInterFoam, which I know is implemented in InterFoam solver in the newer versions.
I developed some meshes for the case and I've updated the other dictionaries to fit in but I'm currently having problems with residuals. My problem is that I can't figure out why they don't converge, so my results are kind of messy.
I tried different meshes, different schemes, and solutions but with no results.
I would appreciate if you could help me with this problem.
I attached one of my most recent case and some results.
Thank you again,
Luís
I'm editing so I can write here some of my dictionaries.
ddtSchemes
default localEuler rDeltaT;
gradSchemes
default Gauss linear;
limitedGrad cellLimited Gauss linear 1;
divSchemes
div(rhoPhi,U) Gauss linearUpwind grad(U);
div(phi,alpha) Gauss vanLeer;
div(phirb,alpha) Gauss linear;
div(phi,k) Gauss linearUpwind limitedGrad;
div(phi,omega) Gauss linearUpwind limitedGrad;
div((muEff*dev(T(grad(U))))) Gauss linear;
laplacianSchemes
default Gauss linear corrected;
interpolationSchemes
default linear;
snGradSchemes
default corrected;
fluxRequired
default no;
p_rgh;
pcorr;
alpha.water;
solvers
"alpha.water.*"
nAlphaCorr 2;
nAlphaSubCycles 1;
cAlpha 1;
icAlpha 0;
MULESCorr yes;
nLimiterIter 10;
alphaApplyPrevCorr yes;
solver smoothSolver;
smoother symGaussSeidel;
tolerance 1e-8;
relTol 0;
minIter 1;
pcorr
solver PCG;
preconditioner
preconditioner GAMG;
smoother GaussSeidel;
agglomerator faceAreaPair;
mergeLevels 1;
nCellsInCoarsestLevel 10;
cacheAgglomeration true;
tolerance 1e-5;
relTol 0;
tolerance 1e-5;
relTol 0;
p_rgh
solver GAMG;
smoother DIC;
mergeLevels 1;
tolerance 1e-7;
relTol 0.01;
p_rghFinal
$p_rgh;
relTol 0;
"(U|k|omega).*"
nSweeps 1;
tolerance 1e-7;
relTol 0.1;
minIter 1;
PIMPLE
momentumPredictor yes;
nOuterCorrectors 1;
nCorrectors 1;
nNonOrthogonalCorrectors 0;
maxCo 0.9;
maxAlphaCo 0.2;
nAlphaSweepIter 1;
rDeltaTSmoothingCoeff 0.05;
rDeltaTDampingCoeff 0.5;
maxDeltaT 1;
relaxationFactors
fields
equations
".*" 1;
cache
grad(U);
castellatedMesh true;
snap true;
addLayers false;
// Geometry. Definition of all surfaces. All surfaces are of class
// searchableSurface.
// Surfaces are used
// - to specify refinement for any mesh cell intersecting it
// - to specify refinement for any mesh cell inside/outside/near
// - to 'snap' the mesh boundary to the surface
geometry
wigleycentre.stl
type triSurfaceMesh;
name hull;
patchInfo
type wall;
refinementBox
type searchableBox;
min (-1.6 -12 -0.5);
max (1.6 -11.75 0.5);
// Settings for the castellatedMesh generation.
castellatedMeshControls
// Refinement parameters
// If local number of cells is >= maxLocalCells on any processor
// switches from from refinement followed by balancing
// (current method) to (weighted) balancing before refinement.
maxLocalCells 100000;
// Overall cell limit (approximately). Refinement will stop immediately
// upon reaching this number so a refinement level might not complete.
// Note that this is the number of cells before removing the part which
// is not 'visible' from the keepPoint. The final number of cells might
// actually be a lot less.
maxGlobalCells 2000000;
// The surface refinement loop might spend lots of iterations refining just a
// few cells. This setting will cause refinement to stop if <= minimumRefine
// are selected for refinement. Note: it will at least do one iteration
// (unless the number of cells to refine is 0)
minRefinementCells 0;
// Number of buffer layers between different levels.
// 1 means normal 2:1 refinement restriction, larger means slower
// refinement.
nCellsBetweenLevels 3;
// Explicit feature edge refinement
// Specifies a level for any cell intersected by its edges.
// This is a featureEdgeMesh, read from constant/triSurface for now.
features
file "wigleycentre.eMesh";
level 3;
// Surface based refinement
// Specifies two levels for every surface. The first is the minimum level,
// every cell intersecting a surface gets refined up to the minimum level.
// The second level is the maximum level. Cells that 'see' multiple
// intersections where the intersections make an
// angle > resolveFeatureAngle get refined up to the maximum level.
refinementSurfaces
hull
// Surface-wise min and max refinement level
level (3 3);
resolveFeatureAngle 45;
// Region-wise refinement
// Specifies refinement level for cells in relation to a surface. One of
// three modes
// - distance. 'levels' specifies per distance to the surface the
// wanted refinement level. The distances need to be specified in
// descending order.
// - inside. 'levels' is only one entry and only the level is used. All
// cells inside the surface get refined up to the level. The surface
// needs to be closed for this to be possible.
// - outside. Same but cells outside.
refinementRegions
refinementBox
mode inside;
levels ((1 1));
// Mesh selection
// After refinement patches get added for all refinementSurfaces and
// all cells intersecting the surfaces get put into these patches. The
// section reachable from the locationInMesh is kept.
// NOTE: This point should never be on a face, always inside a cell, even
// after refinement.
locationInMesh (2 0 0);
// Whether any faceZones (as specified in the refinementSurfaces)
// are only on the boundary of corresponding cellZones or also allow
// free-standing zone faces. Not used if there are no faceZones.
allowFreeStandingZoneFaces true;
// Settings for the snapping.
snapControls
//- Number of patch smoothing iterations before finding correspondence
// to surface
nSmoothPatch 3;
//- Relative distance for points to be attracted by surface feature point
// or edge. True distance is this factor times local
// maximum edge length.
// tolerance 4.0;
tolerance 1.0;
//- Number of mesh displacement relaxation iterations.
nSolveIter 300;
//- Maximum number of snapping relaxation iterations. Should stop
// before upon reaching a correct mesh.
nRelaxIter 10;
nFeatureSnapIter 10;
// Settings for the layer addition.
addLayersControls
// Are the thickness parameters below relative to the undistorted
// size of the refined cell outside layer (true) or absolute sizes (false).
relativeSizes true;
// Per final patch (so not geometry!) the layer information
layers
hull
nSurfaceLayers 3;
// Expansion factor for layer mesh
expansionRatio 1.5;
// Wanted thickness of final added cell layer. If multiple layers
// is the thickness of the layer furthest away from the wall.
// Relative to undistorted size of cell outside layer.
// See relativeSizes parameter.
finalLayerThickness 0.7;
// Minimum thickness of cell layer. If for any reason layer
// cannot be above minThickness do not add layer.
minThickness 0.25;
// If points get not extruded do nGrow layers of connected faces that are
// also not grown. This helps convergence of the layer addition process
// close to features.
// Note: changed(corrected) w.r.t 17x! (didn't do anything in 17x)
nGrow 0;
// Advanced settings
// When not to extrude surface. 0 is flat surface, 90 is when two faces
// are perpendicular
featureAngle 60;
// Maximum number of snapping relaxation iterations. Should stop
nRelaxIter 5;
// Number of smoothing iterations of surface normals
nSmoothSurfaceNormals 1;
// Number of smoothing iterations of interior mesh movement direction
nSmoothNormals 3;
// Smooth layer thickness over surface patches
nSmoothThickness 10;
// Stop layer growth on highly warped cells
maxFaceThicknessRatio 0.5;
// Reduce layer growth where ratio thickness to medial
// distance is large
maxThicknessToMedialRatio 0.3;
// Angle used to pick up medial axis points
// Note: changed(corrected) w.r.t 17x! 90 degrees corresponds to 130 in 17x.
minMedianAxisAngle 90;
// Create buffer region for new layer terminations
nBufferCellsNoExtrude 0;
// Overall max number of layer addition iterations. The mesher will exit
// if it reaches this number of iterations; possibly with an illegal
// mesh.
nLayerIter 50;
// Max number of iterations after which relaxed meshQuality controls
// get used. Up to nRelaxIter it uses the settings in meshQualityControls,
// after nRelaxIter it uses the values in meshQualityControls::relaxed.
nRelaxedIter 20;
// Generic mesh quality settings. At any undoable phase these determine
// where to undo.
meshQualityControls
#include "meshQualityDict"
// Advanced
// Flags for optional output
// 0 : only write final meshes
// 1 : write intermediate meshes
// 2 : write volScalarField with cellLevel for postprocessing
// 4 : write current intersections as .obj files
debug 0;
// Merge tolerance. Is fraction of overall bounding box of initial mesh.
// Note: the write tolerance needs to be higher than this.
mergeTolerance 1E-6;
convertToMeters 1;
vertices
(-15 -24 -9) //0
(-8 -24 -9) //1
(2 -24 -9) //2
(7.5 -24 -9) //3
(7.5 -12 -9) //4
(2 -12 -9) //5
(-8 -12 -9) //6
(-15 -12 -9) //7
(7.5 0 -9) //8
(2 0 -9) //9
(-8 0 -9) //10
(-15 0 -9) //11
(-15 -24 -0.75) //12
(-8 -24 -0.75) //13
(2 -24 -0.5) //14
(7.5 -24 -0.75) //15
(7.5 -12 -0.75) //16
(2 -12 -0.75) //17
(-8 -12 -0.75) //18
(-15 -12 -0.75) //19
(7.5 0 -0.75) //20
(2 0 -0.75) //21
(-8 0 -0.75) //22
(-15 0 -0.75) //23
(-15 -24 0.75) //24
(-8 -24 0.75) //25
(2 -24 0.75) //26
(7.5 -24 0.75) //27
(7.5 -12 0.75) //28
(2 -12 0.75) //29
(-8 -12 0.75) //30
(-15 -12 0.75) //31
(7.5 0 0.75) //32
(2 0 0.75) //33
(-8 0 0.75) //34
(-15 0 0.75) //35
(-15 -24 2.25) //36
(-8 -24 2.25) //37
(2 -24 2.25) //38
(7.5 -24 2.25) //39
(7.5 -12 2.25) //40
(2 -12 2.25) //41
(-8 -12 2.25) //42
(-15 -12 2.25) //43
(7.5 0 2.25) //44
(2 0 2.25) //45
(-8 0 2.25) //46
(-15 0 2.25) //47
blocks
//bellow 6
hex (7 6 10 11 19 18 22 23) (20 50 30) simpleGrading (0.8 5 0.1)
hex (6 5 9 10 18 17 21 22) (55 50 30) simpleGrading (1 5 0.1)
hex (5 4 8 9 17 16 20 21) (18 50 30) simpleGrading (1 5 0.1)
//middle 6
hex (19 18 22 23 31 30 34 35) (20 50 20) simpleGrading (0.8 5 1)
hex (18 17 21 22 30 29 33 34) (55 50 20) simpleGrading (1 5 1)
hex (17 16 20 21 29 28 32 33) (18 50 20) simpleGrading (1 5 1)
//upper 6
hex (31 30 34 35 43 42 46 47) (20 50 10) simpleGrading (0.8 5 5)
hex (30 29 33 34 42 41 45 46) (55 50 10) simpleGrading (1 5 5)
hex (29 28 32 33 41 40 44 45) (18 50 10) simpleGrading (1 5 5)
edges
boundary
atmosphere
type patch;
faces
(43 42 46 47)
(42 41 45 46)
(41 40 44 45)
inlet
type patch;
faces
(4 8 20 16)
(16 20 32 28)
(28 32 44 40)
outlet
type patch;
faces
(7 19 23 11)
(19 31 35 23)
(31 43 47 35)
bottom
type symmetryPlane;
faces
(7 11 10 6)
(6 10 9 5)
(5 9 8 4)
side_left
type symmetryPlane;
faces
(7 6 18 19)
(19 18 30 31)
(31 30 42 43)
(6 5 17 18)
(18 17 29 30)
(30 29 41 42)
(5 4 16 17)
(17 16 28 29)
(29 28 40 41)
side_right
type symmetryPlane;
faces
(11 23 22 10)
(10 22 21 9)
(9 21 20 8)
(23 35 34 22)
(22 34 33 21)
(21 33 32 20)
(35 47 46 34)
(34 46 45 33)
(33 45 44 32)
mergePatchPairs
