OpenFOAM5 Chemkin running error - sprayFoam
Old   August 20, 2018, 03:21
Default OpenFOAM5 Chemkin running error - sprayFoam
Tim
timb12 is on a distinguished road
Hi there,
I am very new to OpenFOAM and have been using it as part of my undergraduate thesis. I have been using the aachenBomb tutorial (under the sprayFoam solver) as a basis for my project, which is simulating the injection and combustion of n-dodecane.
I have created and successfully run the wedge mesh to convert it to 2D.
However, I am in the process now of converting the fuel n-heptane to n-dodecane to suit my case. I have been given two files to replace the chem.imp and therm.dat files in the aachenBomb case, that have been used successfully in openFoam4 for n-dodecane.
However, I am getting the following error message. I have not modified the files at all, and in their current form they work in openFOAM4.
nProcs : 1
fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 10)
allowSystemOperations : Allowing user-supplied system call operations
Create time
Create mesh for time = 0
PIMPLE: Operating solver in PISO mode
Reading g
Creating combustion model
Selecting combustion model PaSR<psiChemistryCombustion>
Selecting chemistry type
chemistrySolver ode;
chemistryThermo psi;
Selecting thermodynamics package
type hePsiThermo;
mixture reactingMixture;
transport sutherland;
thermo janaf;
energy sensibleEnthalpy;
equationOfState perfectGas;
specie specie;
Selecting chemistryReader chemkinReader
Reading CHEMKIN thermo data in new file format
--> FOAM FATAL ERROR:
while reading thermodynamic specie name on line 3
'N2 121286N 2 G 0300.00 5000.00 1000.00 1
From function int Foam::chemkinReader::lex()
in file chemistryReaders/chemkinReader/chemkinLexer.L at line 1514.
FOAM exiting
Is this simply a formatting error being picked up by openFOAM? or something different between the chemkin readers of openfoam4 and openfoam5.
Thanks,
Tim
timb12 is offline   Reply With Quote
aachenbomb, chemkin, error, sprayfoam
Error problem while running sadia d lts tutorial kane OpenFOAM Running, Solving & CFD 2 May 26, 2018 03:38
Error Running Design of Experiments in ANSYS Fluent tytrzecki FLUENT 0 April 22, 2018 15:01
CHEMKIN 18.2 Example Running Issue Plum_Flavoured_Biscuit ANSYS 3 March 16, 2018 10:22
[foam-extend.org] Foam Extend 3.2 in ubuntu 16.04 LTS JMosiezny OpenFOAM Installation 15 December 9, 2017 08:20
Problem in running coarse mesh(on the other hand fine mesh is running) ashokmoravaneni OpenFOAM 7 July 17, 2017 04:56
