[Sponsors] | |||||
mba olufemi
Rep Power: 9 ![]() |
I am not entirely sure this is the right place to ask my question, but since it is related to the boundary conditions maybe someone could help. I am trying to setup a simulation of air flowing inside of a pipe (tube) using HELYX-OS. I followed the nice slides of Mr Combest found here. http://download2.nust.na/pub4/source...2013_Jeju/Tue/Track2-3_DanielCombest.tar The example provided ran without problems. It simulates water running in a pipe of diameter 0.1 m and 2.5 m in length as Steady>Incompressible>Laminar flow. Now, I am trying to modify the case model using the same mesh (I repeat, just a cylinder with an input patch, an output patch and a tube no-slip fixed wall) to Steady>Compressible>Laminar flow for air at the speed of 80 m/s. Eventually, if successful, I will modify the geometry fron cylinder to cone, which is what I really need. But the problem I have is that it does not run at all. If I choose the same settings like on the example (input velocity “Fixed Value = 80” , input pressure “Zero Gradient”; outlet velocity Zero Gradient and Pressure “Fixed Value = 0” ) then HELYX-OS selects rhoSimpleFoam as the solver but it exits with the error: Foam: :error: : printStack(Foam: :0stream&) at ??:? I have experimented with different settings but always get an error. Could someone please help? Thanks a lot. Mba |
Robin Kamenicky
Rep Power: 12 ![]() |
Hi mba,
I do not have any experience with HELYX-OS but you might want to change the outlet pressure. If you use 0 you will get a floating point error. If you want to resemble 0 Pa value use small pressure such as 0.001Pa. Also the zeroGradient velocity at the outlet can make a problem, when the flow is not fully developed. Let me know whether it works. Kind regards, Robin |
| Thread Tools | Search this Thread |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| mass flow in is not equal to mass flow out | saii | CFX | 12 | March 19, 2018 06:21 |
| Different flow patterns in CFX and Fluent | avi@lpsc | FLUENT | 4 | April 8, 2012 07:12 |
| Flow meter Design | CD adapco Group Marketing | Siemens | 3 | June 21, 2011 09:33 |
| potential flow vs. Euler flow | curious ... | Main CFD Forum | 23 | July 21, 2006 08:40 |
| Plug Flow | Franck | Main CFD Forum | 3 | September 4, 2003 06:57 |
