how to set initial value of k and epsilon for a buoyant flow case |
Pu Gong
Rep Power: 8 ![]() |
Hi foamers,
I know wiki https://en.wikipedia.org/wiki/Turbulence_kinetic_energy gives equations on k and epsilon based on the inlet velocity and the pipe hydraulic diameter. However in my case, I am modeling a buoyant flow cased by a heat source in a sealed room using buoyantBoussinesqPimplefoam,and there is no inlet and therefore the inlet velocity and hydraulic diameter do not exist. Is it still able to calculate k and epsilon in this situation? cheers |
Robin Kamenicky
Rep Power: 12 ![]() |
Hi Pu,
indeed interesting question. Certainly you cannot define k and epsilon to be 0, this would lead to floating point error. The values calculated in the simulation are very dependent on your BCs like heat flux. If you have high heat flux, you could see quite big values. This can lead to big gradients across the domain. As I understand the purpose of these two values is to have as accurate values as possible but they are not exact. So try to guess the most appropriate values and inspire yourself by the tutorial cases. You can try to run your calculation have a look on velocities you get and adapt your BCs. You might try to experiment a bit and have a look whether results changes with various values or only convergence time changes. Well, I have not probably given to you an answer you wanted. I have just a limited experience which I can share. Somebody else might add a note. Kind regards, Robin |
Display Modes | |
Segmentation fault when using reactingFOAM for Fluids | Tommy Floessner | OpenFOAM Running, Solving & CFD | 4 | April 22, 2018 12:30 |
chtMultiRegionSimpleFoam turbulent case | Aditya Patil | OpenFOAM Running, Solving & CFD | 6 | April 24, 2017 22:13 |
simpleFoam error - "Floating point exception" | mbcx4jc2 | OpenFOAM Running, Solving & CFD | 12 | August 4, 2015 02:20 |
calculation stops after few time steps | sivakumar | OpenFOAM Running, Solving & CFD | 7 | March 17, 2013 06:37 |
Orifice Plate with a fully developed flow - Problems with convergence | jonmec | OpenFOAM Running, Solving & CFD | 3 | July 28, 2011 05:24 |
