Hydraulic Wheel Simulation in an Open Channel |
Salim Homsany
Rep Power: 0 ![]() |
Hey everyone.
I'm currently doing simulations of a turbulent flux in an open channel which has a static hydraulic wheel with the solver interFoam. The 2D mesh was done using SALOME and the configuration of the wheel's axis and the depth is shown in the figure. The internal field velocity for water is uniform (0.172028 0 0) and the air should have a velocity equal to zero at all instant. The assigned boundary conditions are for U: Code:
boundaryField { back { type empty; } bottom { type noSlip; } waterwheel { type noSlip; } front { type empty; } waterinlet { type fixedValue; value uniform (0.172028 0 0); } airinlet { type fixedValue; value uniform (0 0 0); } atmosphere { type pressureInletOutletVelocity; value uniform (0 0 0); } outlet { type inletOutlet; inletValue uniform (0 0 0); } } Code:
dimensions [1 -1 -2 0 0 0 0]; internalField uniform 0; boundaryField { waterinlet { type fixedFluxPressure; value uniform 0; } airinlet { type fixedFluxPressure; value uniform 0; } outlet { type prghPressure; p uniform 0; } bottom { type fixedFluxPressure; value uniform 0; } waterwheel { type fixedFluxPressure; value uniform 0; } atmosphere { type totalPressure; p0 uniform 0; } front { type empty; } back { type empty; } } Code:
boundaryField { back { type empty; } bottom { type zeroGradient; } waterwheel { type zeroGradient; } front { type empty; } waterinlet { type fixedValue; value uniform 1; } airinlet { type fixedValue; value uniform 0; } atmosphere { type inletOutlet; inletValue uniform 0; value uniform 0; } outlet { type zeroGradient; } } Code:
dimensions [0 2 -2 0 0 0 0]; internalField uniform 1.1098e-4; boundaryField { waterinlet { type fixedValue; value uniform 1.1098e-4; } airinlet { type fixedValue; value uniform 1.1098e-4; } bottom { type kqRWallFunction; value uniform 0; } waterwheel { type kqRWallFunction; value uniform 0; } outlet { type inletOutlet; inletValue uniform 1.1098e-4; value uniform 1.1098e-4; } atmosphere { type inletOutlet; inletValue uniform 1.1098e-4; value uniform 1.1098e-4; } front { type empty; } back { type empty; } } Code:
internalField uniform 5.6838; boundaryField { waterinlet { type fixedValue; value uniform 5.6838; } airinlet { type fixedValue; value uniform 5.6838; } bottom { type omegaWallFunction; value uniform 0.002; } waterwheel { type omegaWallFunction; value uniform 0.002; } outlet { type inletOutlet; inletValue uniform 5.6838; value uniform 5.6838; } atmosphere { type inletOutlet; inletValue uniform 5.6838; value uniform 5.6838; } front { type empty; } back { type empty; } } So far, I think it may be: 1. Boundary and initial conditions. 2. The mesh. 3. Perhaps, I have to do a modification to the InterFoam code. Could someone please, verify which of the given reasons is what causing my results? Otherwise, which is the real problem? Thank you very much to all. |
Display Modes | |
Fluent Open Channel Simulation | ahammack | Fluent Multiphase | 0 | October 12, 2016 12:58 |
Open Channel Flow | ElanMorin | FLUENT | 4 | February 25, 2015 16:26 |
centOS 5.6 : paraFoam not working | yossi | OpenFOAM Installation | 2 | October 9, 2013 01:41 |
"parabolicVelocity" in OpenFoam 2.1.0 ? | sawyer86 | OpenFOAM Running, Solving & CFD | 21 | February 7, 2012 11:44 |
OpenFOAM with IBM AIX | matthias | OpenFOAM Installation | 20 | March 25, 2008 02:36 |
