reactingMultiphaseEulerFoam + cyclicACMI compatibal? |
January 26, 2021, 03:36 |
Rep Power: 8 |
Hi all,
OF Version 7, solver: reactingMultiphaseEulerFoam i am trying to run a simulation with the solver reactingMultiphaseEulerFoam. Before that i created 2 meshes, which i merged with mergeMeshes. for the interface i use cyclicalACMI, i already executed every necessary step successfully. i can run pimpleFoam, icoFoam & simpleFoam with no problem, but when i switch to reactingMultiphaseEulerFoam or reactingTwoPhaseEulerFoam, the solver does not even start. i attached a screenshot. my question is, is cyclicACMI compatibal with that solver? or is cyclicalACMI specifically created for certain solvers? cheers Edit_1: i found a bug report on that issue: https://bugs.openfoam.org/view.php?id=3052 its not actually a bug, but i think cyclicACMI is not currently supported. i also analyzed the solvers which can run that internal boundary, e.g. pimpleFoam and interFoam, and they support dynamic meshes. Last edited by geth03; January 26, 2021 at 07:16. Reason: tested icoFoam, simpleFoam & reactingTwoPhaseEulerFoam, too. |
January 27, 2021, 04:14 |
Rep Power: 8 |
so i finally fixed it somehow.
the problem was that initial boundary values were not well set for cyclicacmi patches. |
April 25, 2023, 08:34 |
Vinzenz Götz
Rep Power: 5 |
Hello Geth,
can you tell me how you fixed the issue? Best regards, Vinz |
April 25, 2023, 10:19 |
Rep Power: 8 |
I cant remember exactly what i did to fix it to be honest, i am working with another mesh now, so i dont have that problem anymore.
Maybe you can describe your problem in detail (what you want to simulate, your mesh, solver, version, why does it now work, what is the error message) and i can try to help you. Kind regards |
April 27, 2023, 01:34 |
Vinzenz Götz
Rep Power: 5 |
Thanks for your reply.
I am trying to simulate a sixth of a vortex tube. My mesh is made with snappyHexMesh. sHM crashes when the cyclicAMI patches are actually specified as cyclicAMI, so I mesh them as walls and afterwards use createPatch to change them to cyclicAMI. I used many more ways of achieving that. Even when not decomposed, the solver crashes. I'm using reactingTwoPhaseEulerFoam on OF-v2212. Error is always: Code:
--> FOAM FATAL ERROR: (openfoam-2212) Unable to set target face for source face 19081 From virtual bool Foam::faceAreaWeightAMI::setNextFaces(Foam::label&, Foam::label&, Foam::label&, const Foam::bitSet&, Foam::labelList&, const Foam::DynamicList<int>&, bool) const in file AMIInterpolation/AMIInterpolation/faceAreaWeightAMI/faceAreaWeightAMI.C at line 361. Vinz |
rhoSimpleFoam MRF cyclicACMI centrifugal compressor | dcook | OpenFOAM Running, Solving & CFD | 3 | February 5, 2021 10:13 |
Flux across cyclicACMI coupled patches | j.lisanti | OpenFOAM Programming & Development | 0 | June 15, 2020 09:31 |
cyclicACMI + cyclic | Yosmcer | OpenFOAM Pre-Processing | 18 | February 12, 2019 20:12 |
Problem with periodically repeated partially overlapping patches / nested cyclicACMI | Nysander | OpenFOAM Running, Solving & CFD | 1 | October 10, 2017 10:01 |
cyclicAMI / cyclicACMI OF 2.3 | Peter Müller | OpenFOAM Running, Solving & CFD | 0 | February 21, 2014 09:36 |
