Peng Liang
Rep Power: 13 ![]() |
Dear Foamers,
I am going to run my 3D simualtion on a cluster. I can run on each node the simulation without problem. But when I want to allocate the simulation into different nodes at the same time using the following pbs script, it turns out to run only in a single node. My openfoam version is 2.4.x. #!/bin/bash #PBS -j oe #PBS -l walltime=10:00:00 #PBS -N 3D-Arc-Welding #PBS -l nodes=2: ppn=8 #PBS -m abe #PBS -q default . ~/.bashrc cd $PBS_O_WORKDIR mpirun --mca btl ^openib -np 16 ArgonPlasmaMultiRegionSimpleFoam -parallel>run.\ log For this cluster this is a sample code similar to my problem, but I don't know how to apply that to my case, itis as follows: #!/bin/bash #PBS -l walltime=01:00:00 #PBS -l nice=19 #PBS -q default #PBS -l nodes=6: ppn=16 mpiexec -n 16 -host n001 hostname : -n 16 -host n002 hostname : -n 16 -host n003 hostname : -n 16 -host n004 hostname : -n 16 -host n005 hostname : -n 16 -host n006 hostname | sort echo "end" Can anyone give me suggestions to correct it? Thank you. Bests, Peng |
Rep Power: 25 ![]() |
If I recall correctly running
--mca btl ^openib would tell OpenMPI to not use infiniband interfaces, isn't that the opposite of what you want? I would always run --mca btl ^tcp previously, but perhaps something has changed? The code you have should run fine, can you please post the logfile from the cluster? If it only runs on a single node and you allocate all the MPI ranks to that node, OpenMPI should abort or give you a warning, so I'm not sure how it would run that way. |
#3 | |
Peng Liang
did not launch the job. This error was first reported for process rank 0; it may have occurred for other processes as well. NOTE: A common cause for this error is misspelling a mpirun command line parameter option (remember that mpirun interprets the first unrecognized command line token as the executable). Node: n001 Executable: ArgonPlasmaMultiRegionSimpleFoam -------------------------------------------------------------------------- 16 total processes failed to start And when I use my own script, I actually didn't get any errors if I take the line ". $WM_PROJECT_DIR/etc/bashrc" away and it runs as if no problems happened. But actually only in single node. But if I add that line, I got the error: "mpirun was unable to find the specified executable file, and therefore did not launch the job. This error was first reported for process rank 0; it may have occurred for other processes as well. NOTE: A common cause for this error is misspelling a mpirun command line parameter option (remember that mpirun interprets the first unrecognized command line token as the executable). Node: n002 Executable: ArgonPlasmaMultiRegionSimpleFoam -------------------------------------------------------------------------- 16 total processes failed to start" |
Display Modes | |
Frequently Asked Questions about Installing OpenFOAM | wyldckat | OpenFOAM Installation | 3 | November 14, 2023 11:58 |
Some questions about a multi region case run in parallel | zfaraday | OpenFOAM Running, Solving & CFD | 5 | February 23, 2017 10:25 |
New OpenFOAM Forum Structure | jola | OpenFOAM | 2 | October 19, 2011 06:55 |
Cant run in parallel on two nodes using OpenMPI | CHristofer | Main CFD Forum | 0 | October 26, 2007 09:54 |
Minimum number of nodes to run CFX in parallel | Rui | CFX | 3 | April 11, 2005 20:46 |
