October 23, 2018, 14:41 |
Ignition not working with reactingFoam
Murilo Mendonça
Rep Power: 7 |
Dear Foamers,
I have been trying to simulate a non-premixed combustion on the attached geometry. The fuel enters through the small centered pipe whereas the air, through the two others on the upper and lower side. When I was working with FLUENT, all I needed to do was specify the initial conditions, run a steady state and use it as an initial condition for the transient simulation. Now with OpenFOAM5.0 what happens is that even though I manage to get a stabilized flow, I can't seem to find a way to ignite the reaction. The case I have based myself to follow was reactingFoam/RAS/SandiaD_LTS I have looked through the forum, tried (unsucessfully) to install swak4foam to ignite it artificially, but I can't seem to get it done. Am I missing something here? Thanks! BC's Fuel: CH4, 301K, 3m/s Air: 343K, 10m/s (both holes) |
October 24, 2018, 12:41 |
Murilo Mendonça
Rep Power: 7 |
By looking further in the forum, I have (unsucessfully) tried to ignite it by inserting an Energy Source through the fvOptions file, but I still can't seem to get it done. Next step is to try activating the energySource after the flow is stabilized.
Thoughts? Code:
energySource1 { type scalarSemiImplicitSource; active true; timeStart 0; duration 0.01; scalarSemiImplicitSourceCoeffs { selectionMode all; volumeMode specific; injectionRateSuSp { T (1700 0); } } } |
October 24, 2018, 14:27 |
Getting (stable) ignition for reacting flows can be tricky. However, there are various tutorials that use an energy source for ignition at some point (in time). Here's one example of an fvOptions file : https://github.com/OpenFOAM/OpenFOAM.../gas/fvOptions. A quick scan of yours -- use h instead of T (enthalpy). Other parameters can be taken from the file I've linked. If you're doing non-premixed combustion you might want to run without ignition for a bit to let the flow develop and mix before igniting -- this may help with stability.
Caelan |
November 5, 2018, 07:06 |
Murilo Mendonça
Rep Power: 7 |
Thank you for your answer Caelan!
I was trying for the past few days enabling the heat source by applying to all domain a high Temperature value after 5 seconds (and then switched to enthalpy, as you suggested). But the program will not work that way, making a combustion occur where only air gets in, even before the fluid is stabilized. When trying to create a box cellSet using topoSetDict, I get the following error: Code:
Create time Create polyMesh for time = 0 Reading topoSetDict Time = 0 mesh not changed. Created cellSet ignitionCellSet Applying source boxToCell Adding cells with center within boxes 1((-0.0630417 0.0240592 0.00619917) (0.000372681 -0.0200989 0.00619917)) cellSet ignitionCellSet now size 0 Created cellZoneSet ignition Applying source setToCellZone Adding all cells from cellSet ignitionCellSet ... cellZoneSet ignition now size 0 End Code:
actions ( { name ignitionCellSet; type cellSet; action new; source boxToCell; sourceInfo { box (-0.0630417 0.0240592 0.00619917)(0.000372681 -0.0200989 0.00619917); } } { name ignition; type cellZoneSet; action new; source setToCellZone; sourceInfo { set ignitionCellSet; } } ); Thanks again! Edit: I am using a mesh converted from the ANSYS Fluent mesher. |
November 5, 2018, 12:07 |
Applying a large amount of energy to the whole domain sounds unnecessary and a good way to cause instability. The problem now looks to be that your cellSet is empty. topoSet should select cells with cell centers inside of the box for boxToCell. Make sure that you specify the bottom left and then the top right. You'll also need different z coordinates, even for a 2d mesh.
Caelan |
combustion, ignition, methane, reactingfoam |
about reactingFoam muEff | comingdaytime | OpenFOAM Running, Solving & CFD | 1 | March 20, 2021 15:02 |
what "If" condition means in rebound | brbbhatti | OpenFOAM Programming & Development | 0 | August 12, 2014 09:18 |
how does the ignition model initiate main combustion | mepgzzi | Siemens | 0 | June 23, 2012 14:32 |
DPM parallel is not working but serial is working | johnwinter | FLUENT | 1 | March 27, 2012 02:01 |
Ignition point in reactingFoam? | lfgmarc | OpenFOAM Programming & Development | 0 | July 11, 2011 18:00 |
