ssa
Rep Power: 8 ![]() |
Dear all,
I am simulating a flow inside a closed room. I have done the simulation using RANS k-epsilon model and the simulated results are well in agreement with the experiment results. But in case of LES, the flow field obtained using field averaging is not accurate. I am using smagorinsky model, pimplefoam. (courant number 1, yPlus avg 0.23) Attached are images from the simulation. Any help to rectify the error would be appreciated. I have tried different turbulence models, different schemes, but nothing worked out. Thanks |
Michael Alletto
Rep Power: 16 ![]() |
How does the mesh look like? It is also important to resolve the shear layer.
Santiago Lopez Castano
Comments:
1. Dont use pimpleFoam, the underrelaxation terms for LES plus the outer correctors will give you wtong results 2. The only valid scheme for div(phi,U) is Gauss linear, fourth, and any of the leastSquares family. 3. PISO implemented in FOAM is inconsistent in the tratment of the convective fluxes, thus your Co must be less than 0.5 4. The cell peclet number must be less than 2, due to the 2nd comment. 5. Is your Ksgs/K < 0.2? Finally, have in mind that LES is a completely different animal, wrt RANS. The latter is more foolproof (no offense), as all scales of turbulence are modelled 4. |
ssa
Hi Santiago,
I calculated the peclet number from the last time step and it is more than 2. How to reduce this.? Attached is the peclet number at the center plane. Thanks. ssa. |
ssa
ssa
#9 |
ssa
Hi Santiago,
I have tried with piso with Courant number 0.1 and the results didn't change. If you have time, could you check the case file. ( Case download from Google drive ) and tell your suggestions to improve. Thanks, Senthil |
Display Modes | |
[OpenFOAM.org] compile error in dynamicMesh and thermophysicalModels libraries | NickG | OpenFOAM Installation | 3 | December 30, 2019 00:21 |
[blockMesh] blockMesh with double grading. | spwater | OpenFOAM Meshing & Mesh Conversion | 92 | January 12, 2019 09:00 |
DPM udf error | haghshenasfard | FLUENT | 0 | April 13, 2016 06:35 |
Compiling problems with hello worldC | fw407 | OpenFOAM Installation | 21 | January 6, 2008 17:38 |
user subroutine error | CFDUSER | CFX | 2 | December 9, 2006 06:31 |
