Effective thermal diffusivity formulation (sonicFoam) |
Rep Power: 10 ![]() |
I would like some help in clarifying the implementation of the energy equation in sonicFoam in OpenFOAM: fvScalarMatrix EEqn ( fvm::ddt(rho, e) + fvm::div(phi, e) + fvc::ddt(rho, K) + fvc::div(phi, K) + fvc::div(fvc::absolute(phi/fvc::interpolate(rho), U), p, "div(phiv,p)") - fvm::laplacian(turbulence->alphaEff(), e) == fvOptions(rho, e) ); Specifically, is alphaEff an effective thermal diffusivity which accounts for laminar and turbulent contributions? If so, how is this expressed in an equation? i.e. alphaEff = alpha_lam + alpha_turb? Or another formulation? thanks! Last edited by er99; November 1, 2018 at 07:16. |
Lucky
Rep Power: 68 ![]() ![]() ![]() |
To put it simply, yes alphaEff is alpha_laminar + alpha_turbulent.
Eventually thermo.alphaEff will be called which you can find in the appropriate thermophysical source file for your thermophysical model. E.g. /src/thermophysicalModels/basic/heThermo/heThermo.C |
#3 | |
I am using sensibleInternalEnthalpy and just found this post that states alphaEff is actually: alphaEff = cp/cv(alpha_lam + alpha_turb) alphaEff Is it right? Thanks again for your help! |
Lucky
There is a lot of juggling that happens under-the-hood.
Recall that you're looking at the heat diffusion/conduction term which is divergence of thermal conductivity (kappa in OpenFOAM) times the temperature gradient, which looks very different than laplacian of alphaEff*e. There isn't a mistake in EEqn.h, but the reason for the Cp/Cv is elusive and I have to dig it up later. I'll probably edit this post when I get around to it. |
#5 | |
\begin{equation} \frac{\partial }{\partial t}\Big[\rho(e + k)\Big] = -\nabla \cdot \Big[\rho U(e + k)\Big] - \nabla \cdot ({\bf{U}} p) + \frac{c_p}{c_v}\Big[\alpha_{l} + \alpha_{t}\Big]\nabla(e) \end{equation} Does that look ok? Thanks! |
Lucky
Btw I hope you meant sensibleInternalEnergy and not sensibleInternalEnthalpy.
It's not cp/cv but actually a variable called cpBycpv. cpBycpv when not needed is set to 1 (i.e. when using sensibleEnthalpy) but set to cpBycpv = gamma when needed (i.e. in sensibleInternalEnergy). It turned out to be much simpler than I thought. You have: de = Cv*dT and alpha = kappa / Cp Hence in order to get something that looks like kappa*T, you ordinarily want kappa * T= alpha*Cp * (e / Cv) Conveniently when you call thermo.alpha in OpenFOAM, you actually get (not alpha but something else) thermo.alpha = cpBycpv*alpha which is alpha*gamma or alpha*Cp/Cv for sensibleInternalEnergy... The reason for setting up thermo.alpha in this way is for versatility. Someone might decide to use a sensibleEnthalpy formulation instead of sensibleInternalEnergy formulation. So finally, alphaEff is indeed alpha_laminar + alpha_turbulent, but the way it is written in OpenFOAM in many places, by shoving this cpBycpv in front of it makes it seem elusive. The trick is to not get fooled by this variable that is labeled alpha/alphaEff in OpenFOAM but doesn't actually return the property alpha/alphaEff. |
Display Modes | |
Effective Thermal Conductivity | Merlin | CFX | 2 | July 23, 2015 07:10 |
1D heat flow through rod with changing thermal diffusivity | cjgn44 | System Analysis | 1 | December 7, 2014 20:40 |
BC wallHeatTransfer, alphaWall: Thermal Diffusivity or Conductivity | Johnston81 | OpenFOAM Running, Solving & CFD | 1 | July 25, 2013 14:40 |
Porous Media Effective Thermal Conductivity | Greg Perkins | FLUENT | 3 | August 5, 2001 21:53 |
Info: Short Course On Thermal Design of Electronic Equipment | Arnold Free | Main CFD Forum | 0 | August 10, 1999 10:18 |
