[OpenFOAM 6.x/CentOS 7.3] SimpleFOAM ERROR Floating Point Exception(core dumped) |
Tzu-Yao Huang
Rep Power: 0 ![]() |
Hi everyone, I am simulating flow around DARPA SUBOFF using steady simpleFOAM k-omega SST model, but the metioned error occur.
boundary condition descreption: 1. wall - darpa suboff 2. in - inlet 3. out - outlet 4. sym - symmetry plane error: Code:
#0 Foam::error::printStack(Foam::Ostream&) at ??:? #1 Foam::sigFpe::sigHandler(int) at ??:? #2 ? in /lib64/libc.so.6 #3 Foam::GaussSeidelSmoother::smooth(Foam::word const&, Foam::Field<double>&, Foam::lduMatrix const&, Foam::Field<double> cons, double> const&, Foam::UPtrList<Foam::lduInterfaceField const> const&, unsigned char, int) at ??:? #4 Foam::GaussSeidelSmoother::smooth(Foam::Field<double>&, Foam::Field<double> const&, unsigned char, int) const at ??:? #5 Foam::smoothSolver::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const at ??:? #6 Foam::fvMatrix<Foam::Vector<double> >::solveSegregated(Foam::dictionary const&) at ??:? #7 Foam::fvMatrix<Foam::Vector<double> >::solveSegregatedOrCoupled(Foam::dictionary const&) at ??:? #8 Foam::fvMesh::solve(Foam::fvMatrix<Foam::Vector<double> >&, Foam::dictionary const&) const at ??:? #9 ? at ??:? #10 __libc_start_main in /lib64/libc.so.6 #11 ? at ??:? Floating point exception (core dumped) Code:
Mesh stats points: 228080 faces: 663159 internal faces: 642561 cells: 217620 faces per cell: 6 boundary patches: 4 point zones: 0 face zones: 0 cell zones: 0 Overall number of cells of each type: hexahedra: 217620 prisms: 0 wedges: 0 pyramids: 0 tet wedges: 0 tetrahedra: 0 polyhedra: 0 Checking topology... Boundary definition OK. Cell to face addressing OK. Point usage OK. Upper triangular ordering OK. Face vertices OK. Number of regions: 1 (OK). Checking patch topology for multiply connected surfaces... Patch Faces Points Surface topology in 961 1024 ok (non-closed singly connected) out 961 1024 ok (non-closed singly connected) sym 13096 13340 ok (non-closed singly connected) wall 5580 5702 ok (non-closed singly connected) Checking faceZone topology for multiply connected surfaces... No faceZones found. Checking basic cellZone addressing... No cellZones found. Checking geometry... Overall domain bounding box (-185.03937 -196.85039 -8.9412195e-10) (346.45669 196.85039 196.85039) Mesh has 3 geometric (non-empty/wedge) directions (1 1 1) Mesh has 3 solution (non-empty) directions (1 1 1) Boundary openness (1.4344067e-16 -3.0733581e-16 -5.3925414e-16) OK. Max cell openness = 3.4660301e-16 OK. Max aspect ratio = 35.858454 OK. Minimum face area = 0.0094103014. Maximum face area = 445.01098. Face area magnitudes OK. Min volume = 0.00098242557. Max volume = 4140.3589. Total volume = 24304384. Cell volumes OK. Mesh non-orthogonality Max: 66.862872 average: 14.839491 Non-orthogonality check OK. Face pyramids OK. Max skewness = 0.98146085 OK. Coupled point location match (average 0) OK. Mesh OK. End fvSchemes Code:
ddtSchemes { default steadyState; } gradSchemes { default Gauss linear; } divSchemes { default Gauss linear; } laplacianSchemes { default Gauss linear corrected; } interpolationSchemes { default linear; } snGradSchemes { default corrected; } wallDist { method meshWave; } Code:
solvers { p { solver GAMG; smoother GaussSeidel; tolerance 1e-6; relTol 0.1; } Phi { $p; } "(U|k|omega)" { solver smoothSolver; smoother GaussSeidel; tolerance 1e-8; relTol 0.1; nSweeps 1; } } SIMPLE { nNonOrthogonalCorrectors 0; pRefCell 0; pRefvalue 0; consistent yes; } relaxationFactors { fields { p 0.3; } equations { U 0.9; ".*" 0.9; } } Code:
application simpleFoam; startFrom startTime; startTime 0; stopAt endTime; endTime 200; deltaT 1; writeControl timeStep; writeInterval 20; purgeWrite 0; writeFormat ascii; writePrecision 8; writeConpression off; timeFormat fixed; timePrecision 4; graphFormat gnuplot; runTimeModifiable false; Code:
dimensions [0 1 -1 0 0 0 0]; internalField uniform (9.25485556 0 0); boundaryField { in { type freestream; freestreamValue $internalField; } out { type freestream; freestreamValue $internalField; } sym { type symmetry; } wall { type fixedValue; value uniform (0 0 0); } } Code:
dimensions [0 2 -2 0 0 0 0]; internalField uniform 0; boundaryField { in { type freestreamPressure; freestreamValue $internalField; out { type freestreamPressure; freestreamValue $internalField; } sym { type symmetry; } wall { type zeroGradient; } } Code:
dimensions [0 2 -1 0 0 0 0]; internalField uniform 1.25e-7; boundaryField { in { type freestream; freestreamValue $internalField; } out { type freestream; freestreamValue $internalField; } wall { type freestream; freestreamValue $internalField; } sym { type symmetry; } } Code:
dimensions [0 2 -2 0 0 0 0]; internalField uniform 1.5e-4; // 1.08e-3 = 1.125*(69.4)^2/5e6 // 11=3.9% 18.1=5%; boundaryField { in { type fixedValue; value $internalField; } out { type zeroGradient; } wall { type kqRWallFunction; value $internalField; } sym { type symmetry; } } Code:
dimensions [0 0 -1 0 0 0 0]; internalField uniform 2.236; boundaryField { in { type fixedValue; value $internalField; } out { type zeroGradient; } sym { type symmetry; } wall { type omegaWallFunction; value $internalField; } } ![]() ![]() my case if needed https://drive.google.com/file/d/1YCN...ew?usp=sharing |
Display Modes | |
MPI Error - simpleFoam - Floating Point Exception | scott | OpenFOAM Running, Solving & CFD | 3 | April 13, 2012 16:34 |
simpleFoam Floating point exception error -help | sudhasran | OpenFOAM Running, Solving & CFD | 3 | March 12, 2012 16:23 |
simpleFoam errors... timestep continuity error/Floating point exception | headwing | OpenFOAM | 1 | January 15, 2011 03:04 |
[Gmsh] Gmsh and samplesurface | touf | OpenFOAM Meshing & Mesh Conversion | 2 | December 10, 2007 02:27 |
CFX4.3 -build analysis form | Chie Min | CFX | 5 | July 12, 2001 23:19 |
