Divergence in kOmegaSST while converging for another mesh |
cyln
Rep Power: 10 ![]() |
I am running a URANS simulation using pimpleFoam solver along with kOmegaSST turbulence model. My simulation has been running without any issues, however, I wanted to update my mesh. I kept all BCs and discretization schemes the same, but now I am having a divergnce issue with the new mesh. The properties are quite close. Below are the DETAILED mesh qualities (checkMesh -allGeometry). Can you notice any problematic issue between two meshes? This mesh is converging Code:
Mesh stats points: 10818179 faces: 53648093 internal faces: 53421359 cells: 22300424 faces per cell: 4.80123 boundary patches: 3 point zones: 0 face zones: 3 cell zones: 2 Overall number of cells of each type: hexahedra: 6785013 prisms: 4063020 wedges: 0 pyramids: 234710 tet wedges: 0 tetrahedra: 11217681 polyhedra: 0 Checking topology... Boundary definition OK. Cell to face addressing OK. Point usage OK. Upper triangular ordering OK. Face vertices OK. Number of regions: 1 (OK). Checking patch topology for multiply connected surfaces... Patch Faces Points Surface topology Bounding box FARFIELD 64292 32260 ok (non-closed singly connected) (-3.6 -1.89 -1.638) (5.4594 1.89 1.638) OUTLET 6172 3200 ok (non-closed singly connected) (-3.6 -1.89 -1.638) (-3.6 1.89 1.638) BODY 156270 78137 ok (closed singly connected) (0 -0.105 -0.091) (0.3033 0.105 0.091) Checking geometry... Overall domain bounding box (-3.6 -1.89 -1.638) (5.4594 1.89 1.638) Mesh has 3 geometric (non-empty/wedge) directions (1 1 1) Mesh has 3 solution (non-empty) directions (1 1 1) Boundary openness (-4.75074e-16 5.6058e-16 -5.16538e-16) OK. Max cell openness = 6.56332e-15 OK. Max aspect ratio = 234.03 OK. Minimum face area = 2.54377e-09. Maximum face area = 0.0100949. Face area magnitudes OK. Min volume = 5.77004e-13. Max volume = 0.000334306. Total volume = 86.5231. Cell volumes OK. Mesh non-orthogonality Max: 78.2651 average: 13.3015 *Number of severely non-orthogonal (> 70 degrees) faces: 12. Non-orthogonality check OK. <<Writing 12 non-orthogonal faces to set nonOrthoFaces Face pyramids OK. Max skewness = 2.65922 OK. Coupled point location match (average 0) OK. Face tets OK. *Edges too small, min/max edge length = 4.95773e-06 0.183281, number too small: 304584 <<Writing 304584 points on short edges to set shortEdges All angles in faces OK. Face flatness (1 = flat, 0 = butterfly) : min = 0.924377 average = 0.99978 All face flatness OK. Cell determinant (wellposedness) : minimum: 6.73684e-20 average: 2.86146 ***Cells with small determinant (< 0.001) found, number of cells: 1151198 <<Writing 1151198 under-determined cells to set underdeterminedCells Concave cell check OK. Face interpolation weight : minimum: 0.0767751 average: 0.464583 Face interpolation weight check OK. Face volume ratio : minimum: 0.047799 average: 0.875447 Face volume ratio check OK. Failed 1 mesh checks. End Code:
Mesh stats points: 12257873 faces: 62999283 internal faces: 62781421 cells: 26552434 faces per cell: 4.73707 boundary patches: 3 point zones: 0 face zones: 3 cell zones: 2 Overall number of cells of each type: hexahedra: 7746063 prisms: 3816332 wedges: 0 pyramids: 262510 tet wedges: 0 tetrahedra: 14727529 polyhedra: 0 Checking topology... Boundary definition OK. Cell to face addressing OK. Point usage OK. Upper triangular ordering OK. Face vertices OK. Number of regions: 1 (OK). Checking patch topology for multiply connected surfaces... Patch Faces Points Surface topology Bounding box FARFIELD 64841 32535 ok (non-closed singly connected) (-3.6 -1.89 -1.638) (5.4594 1.89 1.638) OUTLET 6239 3234 ok (non-closed singly connected) (-3.6 -1.89 -1.638) (-3.6 1.89 1.638) BODY 146782 73393 ok (closed singly connected) (0 -0.105 -0.091) (0.3033 0.105 0.091) Checking geometry... Overall domain bounding box (-3.6 -1.89 -1.638) (5.4594 1.89 1.638) Mesh has 3 geometric (non-empty/wedge) directions (1 1 1) Mesh has 3 solution (non-empty) directions (1 1 1) Boundary openness (-3.45339e-17 -2.10547e-16 -6.58183e-17) OK. Max cell openness = 7.26584e-15 OK. Max aspect ratio = 232.805 OK. Minimum face area = 2.35453e-09. Maximum face area = 0.0104033. Face area magnitudes OK. Min volume = 5.0309e-13. Max volume = 0.000305801. Total volume = 86.5231. Cell volumes OK. Mesh non-orthogonality Max: 76.6128 average: 12.7739 *Number of severely non-orthogonal (> 70 degrees) faces: 41. Non-orthogonality check OK. <<Writing 41 non-orthogonal faces to set nonOrthoFaces Face pyramids OK. Max skewness = 2.64733 OK. Coupled point location match (average 0) OK. Face tets OK. *Edges too small, min/max edge length = 4.73886e-06 0.172407, number too small: 281115 <<Writing 281115 points on short edges to set shortEdges All angles in faces OK. Face flatness (1 = flat, 0 = butterfly) : min = 0.939085 average = 0.999831 All face flatness OK. Cell determinant (wellposedness) : minimum: 6.59292e-20 average: 2.78323 ***Cells with small determinant (< 0.001) found, number of cells: 1130274 <<Writing 1130274 under-determined cells to set underdeterminedCells Concave cell check OK. Face interpolation weight : minimum: 0.0722425 average: 0.465362 Face interpolation weight check OK. Face volume ratio : minimum: 0.0518655 average: 0.877726 Face volume ratio check OK. Failed 1 mesh checks. End Last edited by cyln; November 6, 2018 at 23:22. |
Peter Baskovich
Rep Power: 12 ![]() |
Well you are failing the checkMesh in both cases for a start (did you read the logs??). Both give short edge errors and the second gives high non-orthogonality errors and small determinate errors.
You might also want to try the (fairly new) residuals objectFunction https://www.openfoam.com/releases/op...esidual-fields With this you can write out a few timesteps and see where the divergence is occuring. You can also visualise the bad sets from checkMesh to find where they are (my money is on them being in the same place). |
cyln
Hello Peter,
Thanks for your reply. When I use checkMesh only, the mesh does not fail and does not give any fail output. I posted "checkMesh -allGeometry" on purpose to provide more detailed information about the mesh. For the diverging case, the case diverges at the first time step. While both meshes have similar qualities, I wonder why this divergence occurs for the second mesh. What is so different? I am using OF4.1 so not sure if I can use this utility. |
Peter Baskovich
Are you initialising the fields ie with potentialFoam? Are you under-relaxing the first few steps for stability?
cyln
The flow is initialized with the mappped results from the simulation using the first mesh. This simulation has been running for about 2000 time steps without any issues.
pimpleFoam solver already uses under-relaxation in its algorithm, so do I. |
Peter Baskovich
Can you post any more info, case folder, solver logs etc?
There's not much to tell from just the checkMesh |
Display Modes | |
[ICEM] 2D hybrid mesh (unstructured mesh highly dependent on structured mesh parameters) | shubham jain | ANSYS Meshing & Geometry | 1 | April 10, 2017 05:03 |
[snappyHexMesh] SnappyHexMesh no layers and no decent mesh for complex geometry | pizzaspinate | OpenFOAM Meshing & Mesh Conversion | 1 | February 25, 2015 07:05 |
Divergence using Dynamic Mesh | renatovj | FLUENT | 1 | January 5, 2015 18:26 |
[snappyHexMesh] Layers:problem with curvature | giulio.topazio | OpenFOAM Meshing & Mesh Conversion | 10 | August 22, 2012 09:03 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 11:55 |
