Combustion in a cavity
Old   December 5, 2018, 10:30
Default Combustion in a cavity
Mark
Brandani is on a distinguished road
Hi there!
I am trying to model combustion reaction between methane and oxygen in a t-shape cavity geometry.
I managed to implement combustion reactions at different conditions and in different geometries using the reactingFoam solver. All of those simulations were given inlet patches that contained the reactants (CH4, O2) and were transported to one another by specifying velocity at those same inlet patches. A good example of such simulation is the reacting elbow tutorial (https://bit.ly/2KVEiKv)
Now, I am trying to calculate the time it would take to "flush out" oxygen from a cavity by reacting it with methane (see attached file) - the main problem is how to specify a certain height (h in the pic) if you may of that Oxygen i.e. specify initial volume. --- so the difference from above is that my "inlet patch" of O2 would have moved some height before CH4 is introduced into the system.
Please advise on how to go on to implement that.
Thank you!
Brandani is offline   Reply With Quote
Combustion in a cavity Brandani Main CFD Forum 0 December 5, 2018 06:31
Modelling Combustion in Porous Zone tanjinjack FLUENT 2 September 26, 2016 04:10
Partially Premixed Combustion - Direct Fired Boiler oknus FLUENT 0 April 10, 2012 10:52
supersonic combustion cavity flameholder julurusandeep FLUENT 0 April 16, 2011 02:15
Need Similar Combustion Tutorial as my model Arnab Siemens 0 May 24, 2005 18:23
