krzychu111 |
January 9, 2019 08:42 |
High nut values in random place and time
4 Attachment(s)
I'm working on a simple 2D flow. When I changed turbulence model from kEpsilon to kOmegaSST I noticed that simulation works fine for around 300-600 iterations but then in random cell nut value goes quite high (around~1-1000).
Depending on boundary conditions it happens on boundaries or somewhere on the internal field. From then whole simulation goes wrong and number of iterations for omega rises from 1-5 to 200-800 in a single time step. I already tried modifying boundary conditions and refining the mesh but it didn't solve my problem.
Does anybody got any idea what I've done wrong?
Enclosed pictures and boundary conditions.
Thanks a lot,
Krzysztof
p
FoamFile
version 2.0;
format ascii;
class volScalarField;
object p;
dimensions [0 2 -2 0 0 0 0];
internalField uniform 0;
boundaryField
#includeEtc "caseDicts/setConstraintTypes"
inlet-aa
type zeroGradient;
inlet-bb
type zeroGradient;
outlet-close
type fixedValue;
value uniform 0;
outlet-cc
type fixedValue;
value uniform 0;
upperwall-aa
type symmetry;
upperwall-cc
type symmetry;
axi-bb
type symmetry;
axi-close
type symmetry;
a
type zeroGradient;
b
type zeroGradient;
frontAndBackPlanes
type empty;
U
FoamFile
version 2.0;
format ascii;
class volVectorField;
object U;
dimensions [0 1 -1 0 0 0 0];
internalField uniform (20 0 0);
boundaryField
inlet-aa
type freestream;
freestreamValue $internalField;
inlet-bb
type freestream;
outlet-cc
type inletOutlet;
inletValue $internalField;
value $internalField;
outlet-close
type inletOutlet;
a
type fixedValue;
value uniform (0 0 0);
b
type fixedValue;
upperwall-cc
type symmetry;
upperwall-aa
type symmetry;
axi-close
type symmetry;
axi-bb
type symmetry;
frontAndBackPlanes
type empty;
nut
FoamFile
version 2.0;
format ascii;
location "0";
object nut;
dimensions [0 2 -1 0 0 0 0];
boundaryField
inlet-aa
type freestream;
freestreamValue 1e-2;
/*type calculated;
value $internalField;*/
inlet-bb
type freestream;
/*type calculated;
outlet-close
type zeroGradient;
/*type calculated;
//type fixedValue;
//value uniform 0;
outlet-cc
type zeroGradient;
/*type calculated;
//type fixedValue;
//value uniform 0;
upperwall-cc
type symmetry
upperwall-aa
type symmetry
axi-close
type symmetry;
axi-bb
type symmetry;
//value uniform 0;
a
type nutkWallFunction;
value uniform 0;
b
value uniform 0;
frontAndBackPlanes
type empty;
k
FoamFile
version 2.0;
format ascii;
location "0";
object k;
internalField uniform 1;
boundaryField
inlet-aa
type turbulentIntensityKineticEnergyInlet;
intensity 0.05; // 5% turbulent intensity
inlet-bb
outlet-close
type inletOutlet;
outlet-cc
type inletOutlet;
upperwall-cc
type symmetry
upperwall-aa
type symmetry
axi-close
type symmetry;
axi-bb
type symmetry;
a
type kqRWallFunction;
value uniform 0;
b
value uniform 0;
frontAndBackPlanes
type empty;
omega
FoamFile
version 2.0;
format ascii;
object omega;
dimensions [0 0 -1 0 0 0 0];
internalField uniform 1e-10;//$turbulentOmega;
boundaryField
inlet-aa
type inletOutlet;
inlet-bb
type inletOutlet;
outlet-cc
type inletOutlet;
outlet-close
type inletOutlet;
a
type omegaWallFunction;
b
axi-close
type symmetry;
axi-bb
type symmetry;
upperwall-aa
type symmetry
upperwall-cc
type symmetry
frontAndBackPlanes
type empty;
