Roozbeh
Rep Power: 10 ![]() |
Hi guys,
I would like to model a uniform non-local heat generation or heat source within a solid in openFOAM. In FLUENT that could be explicitly set in defining the solid zone, but in openFOAM I am not sure if it is easily available. Does someone have an idea to do that in openFOAM without having to edit the source code? Thanks for your support |
Rep Power: 21 ![]() |
Add an fvOption file to your region folder. Either constant/solid or system/solid depending on your OF version.
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: dev | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; location "system/solid"; object fvOptions; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // options { energySource { type scalarSemiImplicitSource; selectionMode all; // or only part of the domain via a cellZone e.g defined with topoSet volumeMode specific; // source term per volume or total injectionRateSuSp { h (1.5e6 0); // explicit and implicit part of the source term } } } // ************************************************************************* / |
Kevin Habrock
Rep Power: 8 ![]() |
Hallo,
I try to implement a heat source for a solid as well, but it didn“t worked. Maybe you can find my Problem. I use OpenFoam 4.1 and it is a chtMultiRegion case. Code:
heatSource { type scalarSemiImplicitSource; active true; scalarSemiImplicitSourceCoeffs { selectionMode all; // all, cellSet, cellZone, points cellSet magnet; volumeMode specific; // absolute; injectionRateSuSp { T (400 0); // h (1.5e6 0); } } } Code:
Creating finite volume options from "system/fvOptions" Selecting finite volume options model type scalarSemiImplicitSource Source: heatSource - selecting all cells - selected 35200 cell(s) with volume 4.08615e-05 I think wir h it works fine, but when I try to implement a Temperature it doesn“t work. Code:
Solving for solid region magnet --> FOAM Warning : From function virtual void Foam::fv::option::checkApplied() const in file cfdTools/general/fvOptions/fvOption.C at line 118 Source heatSource defined for field T but never used --> FOAM Warning : From function virtual void Foam::fv::option::checkApplied() const in file cfdTools/general/fvOptions/fvOption.C at line 118 Source heatSource defined for field T but never used DICPCG: Solving for h, Initial residual = 0.812167, Final residual = 0.0564586, No Iterations 14 Min/max T:241.843 293.675 ExecutionTime = 72.39 s ClockTime = 72 s Source: http://caefn.com/openfoam/fvoptions-semiimplicitsource And can maybe anyone explain how I can calculate the HeatFlux (Q(Point)), when I know the h and the A but not the Delta T. Delta T = internalField Region A - internalField Region B ? Thank u very much for your help!! And mabye another Question: In my cases I recocnice that when I change the internalField of a solid to 400K, nothing happend too. Is this normal? Best regards ![]() |
Kevin Habrock
Or I should ask other questions.
If I use the scalarSemiImplicitSource in this way, do I give the CellCet magnet a heat flux of 25Watt? Code:
heatSource { type scalarSemiImplicitSource; active true; scalarSemiImplicitSourceCoeffs { selectionMode all; // all, cellSet, cellZone, Points cellSet magnet; volumeMode absolute; injectionRateSuSp { h (25 0); } } } When I use wallHeatFlux than the result is fine. Thanks! Last edited by Kevin.H; March 13, 2019 at 05:32. |
Display Modes | |
[swak4Foam] swak4foam for OpenFOAM 4.0 | mnikku | OpenFOAM Community Contributions | 80 | May 17, 2022 08:06 |
Question about heat transfer coefficient setting for CFX | Anna Tian | CFX | 1 | June 16, 2013 06:28 |
Error finding variable "THERMX" | sunilpatil | CFX | 8 | April 26, 2013 07:00 |
UDF Scalar Code: HT 1 | Greg Perkins | FLUENT | 8 | October 20, 2000 12:40 |
UDFs for Scalar Eqn - Fluid/Solid HT | Greg Perkins | FLUENT | 0 | October 13, 2000 23:03 |
